Any info on this helicopter crash?
thee12nv
Active member
Got this from ar15.com and was wondering if anyone here knew any more info about it?
It is a bell helicopter trying to tow a boat...
Helicopter Skiing Helicopter crash
Small helo used for towing = not smart
Considering that a Bell 206 barely has the power to lift itself and a few pax into the air, it suprises me that a pilot would be stupid enough to think that little 420 shp engine would lift the helicopter and 2 crew, and pull a 2-3,000 lb boat through the water (which adds drag) with another 3 people in it.
He probably could have done it, just not very fast. Put the helo into a hover, add just a little tension on the line, hover forward a bit and the boat would keep pace behind the boat. But that cowboy tried to fly off at high speed, and it's akin to a poodle running full bore towards a fire hydrant with a chain around it's neck....eventually the dog will feel an abrupt jerking motion that'll knock it onto it's arse.
Re: Small helo used for towing = not smart
HueyPilot said:
...it's akin to a poodle running full bore towards a fire hydrant with a chain around it's neck...
:D Best metaphor I've read on here in a while.
(...or is that a simile?)
