UnAnswerd said:Is a gyroplane basically a helicopter with a seperate prop to push it forward????
FracCapt said:In very simple terms....in a gyroplane, the rotor acts in place of a wing, and the prop/engine on the back does the same as it would on an airplane....propel the aircraft through the air. Gyroplanes don't have a physical connection between the engine and rotor, therefore it's just air turning the rotor. Some have a pre-rotator, which just spins the rotor up initially for a vertical - or nearly vertical - takeoff...but that rotor RPM only lasts a short time if you don't immediately get the aircraft moving forward.
Check out:
http://www.aircommand.com/gpage2.html
UnAnswerd said:Man, those sound dangerouse as hell!!!
