Am I honestly a retard???
UnAnswerd
Activity Terminated
I just finished the FAA regulations in ground school, and we're moving on to aspects that deal with aircraft performance. One of the first things we did was cover density altitude, and figure such altitudes given a list of known factors. I completely understand the concepts, and also understand how to figure density altitute. The problem arrose when I needed to divide some numbers, and I said I would need a calculator. My GS instuctor looked at me kind of strange, and said "you can't figure it on paper"? I said that I had completely forgotten how to divide numbers without the use of a calculator. This did not seem to sit well with her. She went on to question me about what I wanted to do with my flying!!! She said that if I ever wanted to fly professionaly, that I should take a basic math course!!! So at this point I feel like a total retard, and all I can do is give some excuse about using calculators since 5th grade...
Now I know that I SHOULD be able to divide numbers on paper, but does anyone think she was just a little over the top? I mean, I was under the impression that you could bring a calculator to the written exam? I really do not see why it is so alarming that I simply cannot divide numbers on paper. I've seen pilots use electronic E6B's, and yet I can't use a $2 calculator?
Would really appreciate some honest advise on this.
Yeah, you're a retard.
I'm kidding! While I generally think it's nice to be able to manually do long multiplication and division, I think your instructor is overreacting.
Any density altitude problems that I've ever had to figure out could be done on the E6B. Not sure what she wanted you to do, but it sounds like she was being a bit crabby.
Also, while flying it seems like most math is rules of thumb, or rounding off to make it easier. Like the 3-6 rule etc.
She's being a typical b#@*h. She has no right giving you any grief. You have what....roughly 4hrs of flight maybe a little more by now? She's might be a little upset that she's not flying with the airlines. The majority of the females I know in aviation that are teaching ground school, compared to sitting left seat in some kind of jet are slim to none. She might have emotional issues. Which school are you going to?
Your 20 miles out from the airport at 10,000 feet. Field Elevation is 1,000 feet. Your doing 120kts accross the ground (or is the ground doing 120kts under you?) anyway, when do you start your descent. By the way its night time, so you can't see the keys of your calculator, and its solar powered.
See the need for division. And this is just the tip of the iceburg.
I'd like to talk to your instructor! You may be a bit rusty but it sounds to me like her social skills may be lacking.
Here's a better response(cut and paste it to her forehead for me!): "...although I've always been taught that whatever resources will be available to you in the actual aircraft can be used during training as well, I would recommend sitting down for a couple of hours and working out some of these problems. The ability to do these problems in your head can be a big asset to your personal skills and in turn lessen your physical workload in flight. And I would also consider some of the "Murphys" of your current method. What happens if you forget or drop your calculator during the flight or the batteries go dead? .......YOU RETARD!! .... Sorry just kidding......couldn't help myself?! Everything prior to "go dead" is honest advice. Negative reinforcement can be a good teaching tool (personally, I don't like it) but the student needs have their confidence level maintained or even boosted through this process. In my opinion, she has failed in this department.
I'm going to go with Paul on this one. Not only will you have to do division on paper, you'll have to do it in your head. Although, I do think that your instructor may be overreacting a bit--some minor math issues (alone) at this point in your training aren't going to sink you.
Goose
Well, I'd reach over and turn on the overhead light so I could see my calculator. That or if I was in a smaller GA airplane, I would turn on one of my two handy flashlights I always carry.
Math is not my strongest skill, and although I could do it on paper if I had to, using a calculator is MUCH faster, and MUCH more accurate then me putting pen to paper.
The important thing is that you know the proper formulas to get the information - what tools you use is your own business.
Maybe I'm giving this guy too much credit, but I don't think this is the kind of division that he's talking about. Your example uses nice round numbers that are trivial to deal with in your head. I think he's thinking of math problems more along the lines of, "Total moment is 264,614.16, and your weight is 2257.8, what's your CG? Whaddya mean you need a calculator? To be a professional, you need to be able to do it on paper!"
Actually, the Garmin 430 will do it for you too, but some basic math isn't going to kill the kid.
-Goose
UnAnswerd said:
... So at this point I feel like a total retard, and all I can do is give some excuse about using calculators since 5th grade...
Oh, way over the top. WHO in their right mind should expect a high school graduate to be capable of simple arithmetic!?!?
To answer your first question, though, ... oh, nevermind.
:rolleyes:
:rolleyes:
:rolleyes:
Thanks for the replies. I feel a little better knowing that using a calculator is not considered an immoral act. Although, I do agree with those who sugjested I sharpen up on the math skills.
I've yet to see even one reply from you that wasn't degrading in nature. Therefore, I will not attempt to defend myself knowing full-well such actions will be done in vain. Despite this, the point you raise may be considered valid to the majority. With this in mind, I will give an honest answer. The calculator was a devise that was legal to use throughout many years of my schooling. Eliminating the need to figure computations on paper also eliminated the need to remember how to do so. Eventually, prior teachings became forgotten, and the road to dependance (on the calculator) was established. Forgive me father.
No, I don't... That is simply a formula that you figure out once for each airplane you fly, it doesn't require the ability to do long division on paper.
An airplane that travels 120kts and descends 500fpm is a 4 times airplane. Take the altitude to be lost in thousands, multiply by 4, and you have how many miles out you need to start down, plus 5 or 10 miles so you don't descend into the traffic pattern.
The answer to your question is 41 miles if you want a 5 mile approach.
9 thousand feet to lose
x
4 (120kts is 2 miles per minute + 500fpm is 2 minutes per thousand feed)
36
5 mile approach
You can figure what "times" airplane you fly by using the ground speed in miles per minute and the descent rate in how many minutes it takes per thousand feet.
For example, in the Diamondjet, we flight plan at 400kts, but in the descent we pick up some speed, so I use 7 miles a minute as the ground speed. 420kts / 60 = 7
We descend at 2,000fpm most of the time, so that works out to .5 minute per thousand feet.
7 x .5 = 3.5
So the Diamond is a 3.5 times airplane.
Lets say we are crusing at FL330 and the airport is at 2,000ft. That is 31,000ft to lose.
You could get an exact number, but it is easier to just figure on 100 to 110 miles out as the descent point. All too often, ATC will control this anyway. :)
This of course changes on shorter routes into the mountains. If we're only at FL280 and the airport is at 6,000ft, then we only have 22,000ft to lose.
22 x 3.5 = about 75 miles
Ahh, that is different...
But then that sort of thing is figured on the ground, not in the air.
I can't do that on paper either, this is why we have calculators.
Ditto... 5th grade was the last year calculators wer forbidden, after that we all had them. By high school algebra, they were REQUIRED, we all had TI-35 or TI-36X calculators in class, you got a demerit if you didn't bring yours.
Perhaps it is a generational phenomenon, or perhaps not. When I went to school we were expected to write legibly, spell correctly, and perform mathematics with pencils, tables, and - - gasp - - even a slide rule in high school. Today my children are not expected to even spell correctly. It sickens me. I was embarrased a few weeks ago to admit to my daughter that I had forgotten the quadratic formula. I would rather die that admit to this forum that I had forgotten how to DIVIDE.
Sorry if you were offended by my response - - I thought I was being rather tame.
My ground school teacher won't do hardly anything without a calculator because why wouldn't you? We are taught to take flashlights with us at night when we fly in our flight bag. Yes, you need a general understanding of how math works, but there is no harm in using a calculator, IMO.
Did you guys know that you can multiply and divide with your slide rule E6B? It's actually pretty simple. Consult your instruction booklet. No calculators necessary.
-Goose
Nope...pull out an approach plate and cross the fixes at the right altitudes and who cares...
-mini
I dunno - I don't think it's as bad as you think. I'm not sure why your children aren't expected to spell correctly - that sounds like a failing of their teacher or perhaps the school as a whole, but I don't see that as a system-wide problem. Certainly I was expected to spell properly when in school. There has been a tendency in today's youth to tear up the English language when writing e-mail, IM's, or on online forums, but that's a function of trying to be cool and fit in. The same teenager that writes "cu l8tr" to his friend via IM can still turn around and write properly when required to for school. Perhaps there are cases where that's not true, but I don't think it's as big a problem as it's made out to be.
As far as the math goes, the use of calulators is just a sign of progress and time moving forward. Everything on my aluminum E6B can be done with a pencil and a piece of paper. Am I being lazy for using the E6B for calculating my fuel burn when I can simply do some elementary math on the back of a Post-It? That slide rule you used in school was a calculator. Who cares whether it's analog or digital? I'm sure you used tables to look up values for the various transcendental functions. I'll bet someone way back when said, "Back in MY day, I had to expand a Taylor series to calculate that - these friggin' lazy kids are just looking up the answer on some dumb table!" :D
In fact, I'd even argue that with every year, kids going off to college are *more* versed in mathematics than they were in the past. Most college freshmen these days have already had a healthy dose of calculus. My old high school is now offering classes in Differential Equations, Vector Calculus, and Fourier Analysis for those that completed the typical calculus regimen back in Middle School. I'm a few years out from High School, but I certainly didn't graduate with all that under my belt.
So I dunno, I don't think our kids are a whole lot less educated now than they were some specific time ago. They're just using different tools to learn.
-mini
How do you plan your descent to hit the fixes at the right altitudes?
I think that's a myth... I went to high school and college in the mid-90s, and we had to do everything the "hard way" first. Of course we didn't use slide rules, but we had to use the quadratic formula, spell, write papers in APA format, etc. Maybe secondary education is different now w/ the internet (wasn't really well known when I was in high school), but I'd be surprised if what you're saying is the norm.
To Unaswerd:
I'm an engineer that has taken Calculus 1, 2, 3, differential equations, and statistics. I still SUCK at doing math in my head. But I can do it w/ a pencil and paper (no calc) if needed. Hardly a necessary skill anymore, but sometimes I'll do it when I'm to lazy to find a calculator. I agree with the others, you're CFI seems like a b****!
-Goose
That slide rule E6B *is* a calculator. It's just an analog one. The only difference between it and an electronic one is the presentation. Well, that and the batteries don't die in the analog one.
:p
Electronic means for weight & balance, and aother things for planning is fine. If you intend to eventually fly jet aircraft, you will need some basic math skills, mostly with whole numbers (3 to 1 descents, 2 to 1, etc). Sure, GPS and FMS systems will do it for you but, sooner or later, you have to do it yourself (system failures, visual approaches).
Best of Luck
CR
Perhaps I failed to effectively communicate in my brief post. I'll attempt to clarify.
On spelling in school. Certainly my high school kids are expected to spell correctly, and have been required to do so for several years. I'm a bit bothered, though, about the philosophy used in Kindergarten and First grade where many of their compositions are approached from the perspective that spelling doesn't count, we just want them to be able to express a thought. I think they could do both (thoughts and words) at the same time, but that's just me. Emphasis on spelling comes later, and Mom & Dad get to help at home. Ultimately, as long as we're involved, I'm satisfied.
Calculators - - slide rules - - circular slide rules... I realize they're all tools, but shouldn't they have some sort of conceptual foundation? It's one thing to type 2 + 2 = but shouldn't one understand something about why? It's one thing to type 2(3+5) in a calculator, but shouldn't one understand that 2(3+5) = 2*3+2*5 or that it's also equal to 2*8 ? I'm not trying to say a prior generation was smarter or better.
But come on... how hard is it to divide on paper? Really?
How do you shop for bargains at the store? Which is the better value, 24 oz for $2.00, or 30 oz for $2.50? Quick? Which one?
I can't even remember the last time I saw a calculator, electronic or otherwise, in an airplane. Even the recent addition of the FMS to the repertoire doesn't do all the mental math that's required.
We're just talking about dividing on paper, right? What's so hard about THAT?!?
It's probably more likely that my reading comprehension skills just plain suck. :)
