Am I a dummy?
Mesabi Miner
Here's a CFI question for you all...
Picture this. You're on right base in a C-172 with a simulated engine out. You're way high, and you've got excess airspeed. You turn final, still way high and with plenty of speed and while in the turn, apply left rudder to enter a slip. You carry the slip around the completion of the turn and take it out prior to touchdown. Am I wrong to say that this is an acceptible maneuver PROVIDED your airspeed doesn't fall off (i.e. approaching a stall/spin accident)? I was recently checked out by a CFI that emphatically told me to take out the slip because "you never slip it in a turn." Am I right or have I been dangerous all these years?
MM
did he explain why you should never slip it in a turn? I cant find a reason why you shouldn't do this? According to the FAA a forward slip and a sideslip both have you tracking over the ground(not turning). As long as you dont approach a stall I see no reason for this to be unsafe, maybe not the best way to do it but unsafe??
I was taught that as long as airspeed holds (nose below the horizon for my private) that you're ok. I used to teach students to put their foot to the floor with the rudder, then track back and forth along a road using aileron, and closely monitoring airspeed. I don't see a problem with what you did.
Thanks. I was a little shocked at how emphatically he told me to re-center the ball. I can still remember my instructor showing me that technique in a Tomahawk during my private training. He was very clear on keeping the nose below the horizon and maintaining airspeed. Tomahawk would come down like a brick with a slip. Come to think of it, it did regardless!
MM
What you discribed is just one tool in your bag of tricks, so use it if you must. That said, as a check instructor I didn't like to see student's doing this as it shows poor planning. It's not something I would fail a student for, but we would definately talk about it and I would usually suggest that they spend a little more time practiceing engine out procedures with their instructor.
Yes, the planning might not be the best but I wouldn't fault someone for being high on an engine out procedure, within reason of course. I'd much rather plan on being a bit high and scrubbing off the altitude than to try to make a perfect pattern and end up trying to stretch a glide.
As for the original question, I don't see anything wrong with the procedure as long as you are aware of what you are doing and keep your airspeed under control. When I was a CFI we would have short approach spot landing contests with the power going to idle abeam the numbers. In the Warrior, that was pretty much a slip all the way from downwind to short final.
Forward slips
Mesabi Miner said:
You're on right base in a C-172 with a simulated engine out. You're way high, and you've got excess airspeed. You turn final, still way high and with plenty of speed and while in the turn, apply left rudder to enter a slip. You carry the slip around the completion of the turn and take it out prior to touchdown . . . . . Am I right or have I been dangerous all these years?
No, you have not been dangerous all of these years. Moreover, forward slips are a completely appropriate and great way to dissipate excess altitude, especially with a simulated engine out. Depending on the situation, in a 172 I might not even bother with flaps and just slip all the way to touchdown.
Just the same, it still might be better just to make a normal turn to final and then slip. But it depends on the situation.
Hope that helps a little more. Forward slips are virtually a lost art because of flaps, but are still an important part of your repertoire.
Did the instructor explain why he didn't think you should slip in a turn?
I'm guessing that his reasoning is if you stall it in a slip in a turn you might spin.
yeah, if you stall in a slip in straight flight you might spin, does this mean that you shouldn't slip at all?
I would guess that his answer to that would be, yes but in a turn the airplane stalls at a higher airspeed.
Ummm.... yes it does, but it does that whether you're in a slip or not. According to that logic you should never turn either, because you might stall.
Short answer, no there is no reason not to slip in a turn. watch you airspeed, just like you do in a coordinated turn to final and in a non-turning slip.
