(I wouldn't put too much faith in using weather radar as an altimeter)
I agree 100%
(I'll bite. How do you do that?)
Did I answer your question? If you were wanting to know how to do it and get it to work within a couple of hundred feet, I apologize, I dont know how to do that.
In Archies defense, nowhere at any time did he ever advocate trying to shoot an approach with a radar as an altimeter. This is a ground mapping exercise and a way to see if your radar is working properly. It's been 10 years since he came to Dallas and did our company training, and yes, he is as boring in person as he is on the tapes.
Xjcaptain, I think A Squared explained it pretty well. A radar wouldn't help in this situation(getting an altimeter setting), because what you are utilizing is a Radar Altimeter, and not a very accurate one at that. Also, you are guesstimating hieght above terrain that is 20, 30 40 or 50 miles ahead of the aircraft.
(Doesn't that depend on the width of your radar beam, and antenna size?)
No. A degree is a degree. Doesn't matter if you have a 6,8, or 80 degree beam spread. If you are using the bottom four degrees of the cone the math works.
As to the original post, if you can't get something by listening in the blind, you in essence have an inop altimeter. Go to your alternate(assuming the WX was forcast to be better than destination) or another suitable ILS that doesn't require a vector to get established. Stay high. Do the full procedure and intercept the GS well before the marker. Follow the GS down and you should get a rough altimeter setting at GS/marker intersection. If you have a radar altimeter you use it. I think in your scenario you were fuel limited. If it's low everywhere your alternate should have the best WX , but since altimeter out is a bonafide emergency, you may have to consider taking the GS all the way to the ground. Or get low enough to get a cell phone signal and call FSS.
Another option is to ask the drunk guy in 22c. He knows everything when it comes to planes.
I agree 100%
