Singlecoil
I don't reMember
- Jul 26, 2002
tarp said:
Now...are you flying a C-172? Go to the Performance charts in Section 5 for Airspeed Calibration using the Alternate Static Source. In the FAA configuration, is the pressure higher or lower. Well the inside cabin pressure is higher because the airspeed corrections all move lower. We all know that the Airspeed is measuring the difference between RAM and static pressure - if the speed is "indicating" less then there must be less of a difference (i.e. the pressure is higher inside).
Huh? I don't have the chart in front of me, but if the corrections move lower, that is because the airspeed is erroneously indicating high. Pull the alternate static and you will notice airspeed higher than normal, altitude higher than normal, and VSI momentarily indicates a climb. All indicate lower than static pressure in the cabin. Read the airspeed indicator, apply the correction from the chart (to lower the figure you are seeing) and be on your merry way.
