Mark Clark has somebody local who can give you the ride, indeed, that is where I got mine. I am pretty sure the instructor/examiner has a sylabus that has been approved by the FAA, although I did not see it during my time. It was very basic, one day event for me. But, that was years ago, your mileage may vary, as they say. The whole training event and ride was just getting used to the aircraft, a steep turn or two and a couple of stalls and slow flight. Nothing like FSI type ride at all. I think I did demonstrate an engine failure glide, no biggie at all.
As a CFI you can give instruction, but I think you will need a waiver from the EAA to do it unless the students are owners in the plane. Can't do commercial ops, remember? But the EAA has/had a program that allowed an exemption. Of course, you insurance carrier may have a bit of say for that.
You may have to put together a maintenance plan for that also, because we don't do 100 hours or annuals, you get a condition inspection instead. The difference is any A&P can sign it off, don't need an IA.
The other difference is you get a pink airworthiness certificate, as it will be certified in the experimental/exibit category. Most FAA guys seem to just check to see if you are ok to fly it, they really don't want to be bothered with a non-standard aircraft. When I go to shows, they ask for the paperwork, and then ask for a ride!
Overall, it has been a darn reliable aircraft. Any problems I have had were mostly related to add on things, like the Darton kits. I took the old radio boxes out, about 200 lbs of gear, and put in a Garmin gps and a King HSI. Dual radios and good to go!
Hung
