FL420
Blues vs. Birds-Tailhook
- Oct 11, 2005
Some good info. can be found here:
http://www.gecgr.co.cu/infoconst/bvirtual/carreteras/ingles/0226.pdf
As I understand it, the weight limits published are operating gross weight of the aircraft, not weight per wheel or weight per strut.
For example, if you were operating an aircraft with a max. certificated gross weight of 70,000# with two wheels on each strut into an airport with a published two wheel weight limit of 65,000#, you could legally operate on that runway if your actual gross weight was kept at or below 65,000#.
