avbug said:
I'm afraid that statement pretty well disqualifies you for the rest of your post. Frank Robinson himself went on record when the R-22 was released in 1979, explaining quite clearly that this was a 'personal helicopter.' It was never designed to handle more than a couple of hundred hours per year, and when the aircraft reaches its airframe overhaul limits, it was designed - originally - to be thrown away. Or, if the owner preferred, to could be stripped and overhauled in Robinson's plant (nowadays, there are authorized overhaul centers which can do it, too.) Frank envisioned the helicopter as a 10-year toy, which at 100-200 hours per year on a 2,000 hour life-limited airframe, was about right.
But, something happened. The training market siezed upon the R-22 as a cheap and reasonably reliable rotor trainer. Robinson changed his tune in a hurry, and he made a fortune. But no one ever really forgot the fact that the helicopter was not designed for training. It was obvious in the erector-set gear, the teetering "dual" cyclic, and low rotor inertia. Frankly it's obvious in other areas, too.
The R-22 is the most popular training helicopter in the world.
LOL... I always enjoy the "popularity makes it good" argument. They are popular because they are CHEAP! Period.
Which is better...that's like asking a student pilot group w(h)eather a low wing piper is better than a high wing cessna. They're airplanes. These are helicopters. You gravitate to that with which you have expereince. Pilots with Bell 47 experience like the Bell (mostly). Pilots with TH-55/Schweitzer/Hiller experience have differenct preferences than one who has only R-22/44 time. One who has experience in several may have a basis for comparison and may prefer one over another...but that doesn't mean that one is necessarily better.
When it comes to these two helicopters - the Schweizer 269/300 series and the Robinson R-22 series - in the training role, one is clearly better. And the accident rates support this fact. The R-22's safety record was so questionable that SFARs were developed for the damn thing. It is very difficult to perform an auto without under or overspeeding in the R-22; there are guys far, far better than me that can't do it consistently. They're either under or over, every other time. In the 300CB even a student pilot can perform nice autos. And the margin for error is much greater. The quality of construction is clear - the gearbox is a beefy affair. Everything from the pitch links to the gear to the mixer, to the dual controls up front, to the ease of pre-flight and maintenance, to the dampers (which are now elastomeric on the CB series, and much less of a mx concern), to the transmission, are simply stronger, beefier, and better. If you compare the two helicopters side by side, this is immediately obvious. In fact, many of the components in the 300 can be found in the Hughes 500. The T/R gearbox is virtually identical, as are the M/R and T/R blades, dampers, and controls. Nothing bolted onto an R-22 is likely to find its way into production turbine helicopters.
As a personal helicopter I'd choose the 300, but I could see either one being reasonably safe in that role - provided the pilot stays current and proficient. When it comes to training, there's no comparison.
Unfortunately, if you don't train in the robbie and you want that first job...almost certainly flight instructing...you'll not qualify for SFAR 73 without 50 hours in type and 200 in helicopters...you need the robinson time to instruct in a robbie.
This is true. However, the 269/300C/CB/CBi aren't exactly chopped liver. It's flown by many flight schools. However, from a strictly job-related standpoint, not having Robbie time can limit your instructor opportunities.
The robinson has low rotor inertia. Complacency and bad judgement can lead to dire circumstances faster, with less time or potential for recovery. For airplane drivers, a rough analogy to training in a robinson vs. an aircraft with more rotor inertia and more stability might be a nosewheel airplane vs. a tailwheel airplane. In cruise, both fly substantially the same, but for takeoff and landing, one exposes pilot erros and flaws more blatently than the other.
I see where you're trying to go with that, but I don't think I completely agree with your analogy. Flown under normal circumstances in a non-flight training role, and without considering the possibility of equipment failure, weather-related problems, etc., both aircraft will take the pilot where he wants to go, requiring about the same degree of proficiency. Throw in a systems-related emergency and you generally have a real handful of a problem in the R-22; less so in the 300. In a noseplower or tailwheel airplane, the 'systems emergency' is likely to be resolved to the level of the pilot's proficiency, regardless of where the third wheel is. In other words, when it counts, the TW vs. noseplower comparison doesn't make any significant difference. It's more of a personal preference type of comparison, and while I agree that some pilots may prefer one type over another, the question relates to these helicopters used in a training role.
In the real world when a student funds his or her own training, cost is a big issue, and more so by a long shot in a helicopter than in a fixed wing aircraft. Robinsons cost less, which means you do a little more flying for the same buck...unless you're particularly well heeled, you probably need all the help you can get.
It may be possible to earn certificates and ratings spending less, overall, in the R-22. I don't consider this a significant factor when comparing the inherent safety in training in these two very different rotorcraft.
Best regards,
-Ryan
