Aircraft tie downs - Big Screw Aircraft Tie-Down
There are various brands out there for aircraft tie downs, the two we hear most about are "the claw" and "flyties". When I got my plane I chose "the claw" but have yet to use them. While at EAA AirVenture this year (2023) I noticed something new being used which I thought were something just provided by Oshkosh but no, they are a product I saw in their booth and it's another type of tie down. They really caught my attention and after speaking with the rep and agreeing with his presentation, I bought a set (without straps). As I have Tie Boss straps, which I really like, I didn't need additional straps. And my claw kit probably has straps too if I needed something different.
The new product that I purchased is "Big Screw Aircraft Tie-Down"
They are light and can be put into the ground with a socket wrench, same size as your oil filter uses, 1 inch. He also includes an impact socket so you can carry an electric socket wrench if you choose, as demonstrated in his video below but I'm skeptical about the weight so for now I'll see how just carry a socket works out.
I also carry a set of the "Big Screw Aircraft Tie-Downs" and a 1" socket in the Cub, which I have not had to use yet. The included straps are heavy, and I already carry a 65m rope and 6 locking carabiners, so I can use them instead of dedicated straps.
I have used 'The Claw" tie down system in a variety of soil conditions for several years and am satisfied with them. The most extreme conditions experienced with them has been in sandy, wet soil with wind gusts over forty knots. I was frankly surprised that they held without any yield.
"The Big Screw" type looks like they would have superior holding capacity in any soil condition. The deal breaker on them for me is that I would not carry the weight and bulk of an impact wrench in our PA-11. You might be able to use a 1/2 inch drive ratchet wrench but that would not allow the downward pressure this device obviously needs while installing them.
I prefer simple ropes over ratchet straps for tie downs. They are lighter and have less packing bulk. In my opinion, they don't take much more time to use as well as having fewer failure points. Incidentally, "The Claw" kit comes with ropes, not straps.
Yeah, the impact wrench, which I have, is heavy and least desired. I have a socket wrench in the bag with the screw tie downs.
I have these tie boss tie downs. Work great and are very light:
I’ve used plastic tent stakes from Lowe’s or Home Depot. Not the 12” ones. 16” or 24”. With boat dock line.
Neal and ve6yeq, if you ever use The "Big Screw" tie down. system in hard, rocky soil with just the ratcheting socket wrench, post a pilot report.
When using a battery powered drill or impact wrench in that situation, the downward force needed for the screw to penetrate is easily applied. You can't apply much downward force when rotating a ratchet wrench and would have to rely on the screw helix having enough pull to penetrate the soil and to get past any small rocks it encounters. If they work without the impact wrench, I would be a customer for them.
I originally bought the claw. Quite frankly, in four years now I've never needed a tie down other than something already available on a paved surface. I carry my tie boss tie downs which have come in handy. I think if I'm going somewhere I know I'll use the big screw option I'll probably bring my impact wrench. That few pounds for one trip won't matter and I sure won't be struggling with trying to put a screw in the ground and look as stupid as I know I will trying to figure out my tent. :)
I also have not had to use the tie-down anchors that I carry, as everywhere I have visited to stop so far has had anchors to spare. But I did come close when I recently dropped by KCDK, and the ramp was completely full, so I had to park on the grass. As the wind was forecast to increase in the afternoon, instead of tying the plane down and heading into town for lunch, I just decided on a quick visit to the beach at the end of the runway.
If you're camping in a stock PA-11, you are a weight and bulk minimalist by necessity.
There is no extended baggage area or belly pod on this airplane. I remove the aft control stick and utilize the cloth baggage compartment, the area above it for light "stuffable" items, and the aft seat to pack the gear. A bungee net with nylon hooks at four corners keep things in place. The net was designed for securing gear on the back of a motorcycle and acquired from Amazon. It is attached to structural tubing stretched from the bottom of the seat to the top diagonals. If you are creative, a three thousand mile, three week trip can be flown with the airplane in this configuration. Lightweight backpacking gear makes it possible.
Ahh okay. Yeah, I'm required to report to ATC as "Carbon Cub Heavy" when in controlled airspace :)
