Air India
I read on Av Herald that at least one pilot was Russian.
The Captain was a Brit. Most of the pax were Indians
If you read the article:
Air traffic control reportedly received no distress message or other communication from the pilot suggesting the aircraft was having mechanical or operational problems. The pilot was reportedly a Russian expatriate, and the copilot was Indian.
Supposedly Air India has a policy in place for mandating smooth landings:
MUMBAI: Air crash investigators worldwide share a belief__that the initial reports on the probable cause of an aircrash usually turn out to be untrue.
The Air India Express top brass would do well to hope that this bit of industry wisdom holds true in the Mangalore aircrash case too since initial reports from aviation circles point at pilot error arising out of the management's highly controversial policies.
According to sources, the AI Express Boeing 737-800 aircraft touched down deep on runway 24 of Mangalore airport, much beyond the stipulated touchdown zone. Why would a senior commander miss the touchdown zone and hit the runway? Here's where the airline management's involvement comes in. There is a diktat for Air India Express pilots which bars hard landings. A circular issued by the airline about a year ago says that landings should not exceed 1.65G.
What is a 1.65G landing? When the undercarriage of a plane touches down on the runway, the sink rate goes from say 200 feet per minute to zero feet per minute in a few seconds. So for a higher sink rate, the impact on touchdown is greater and vice versa. A hard landing typically occurs when the sink rate is high and the aircraft touches down on the runway with a thud instead of doing a smooth transition onto ground.
The hard or smooth quotient of a landing is expressed in a term called "touchdown G". A 1G landing means the force which acted on aircraft tyres at the instant of touchdown is equivalent to the weight of the aircraft (1 x aircraft weight). A 2G landing would mean the force is two times the weight of the aircraft. Higher the value of G, harder the landing. The AI Express circular limits landings to 1.65G, though according to the aircraft manufacturer Boeing's specifications the aircraft can safely handle up to 2.5G landings.
"Every time a landing exceeds 1.65G, the pilot gets hauled up by the air safety department. Two hard landings and the pilot is sent for a training session. Passengers also complain about hard landings and so the airline is particular about smooth landings which are achieved with lower touchdown G values," said a source. Now, one of the ways to achieve a smooth touchdown is to come over the runway at a higher speed and float for some distance before letting the landing gear touch down on the runway. This reduces the G force on impact. "Pilots often land a few feet ahead of the touchdown zone when they float over the runway to make a smooth landing," said a source. "The AI Express commander too seems to have employed these tactics. His aircraft missed the touchdown point," the source added. What the commander executed was a late, smooth touchdown at high speed. "It is indeed pilot error, but it is an error that was forced by the management policy for smooth landings. A hard landing may be an uncomfortable landing, but sometimes it is a safer landing than a smooth landing," the source said.
Capt Z Glusica was popular among his first officers as he allowed them to do landings under his supervision. "Any commander with the kind of experience that Capt Glusica had can safely allow a first officer to land. But the AI Express air safety department is set against it. If a first officer never learns to land under the supervision of an experienced commander, how will he handle a situation if for instance the commander gets incapacitated?" asked the source. "Even if we assume that it was the first officer who touched down late then all that the commander had to do was do a go-around (i.e., take off again and come around for a second attempt at landing) and the aircraft would have landed safely," the official said.
A B737 aircraft can safely do a go-around after touchdown. But it cannot do a safe go-around if the decision to do a go-around is taken late or if it is taken after the reverse thrusters have been deployed (thrust in the opposite direction so as decelerate the aircraft). A go-around after thrust reversal selection is prohibited. "The airline policy is such that pilots try to avoid go-arounds as they have to explain it to the air safety department. A go-around infact is a highly recommended safety procedure when the touchdown is deep. But due to the airline diktat, the commander must have had a few microseconds of indecision after the aircraft touched down. So he seems to have either opted for the go-around late or he did it after deploying reverse thrusters. Since the go-around attempt failed, this is a plausible explanation," said the source.
There are unconfirmed reports that the plane's nose wheel burst after touchdown. It is difficult to bring an aircraft to a halt near the end of a runway as this portion bears aircraft skid marks and rubber desposits which affects braking action. When the plane attempted to lift off again the aircraft's wing hit the localiser (a T-shaped frangible antenna positioned perpendicular to the runway central line and located about 150 feet from the end of the runway) and then plunged into the valley. "Since the wreckage was well off the runway one can say that there seemed to have been an attempt to do a go around. Only investigations will reveal why did the attempt go wrong," says the source.
The pilots also brought in the fatigue angle to explain the wrong decisions taken by the pilot. "It does not matter how many days rest he got prior to these flights that he operated. He took off from Calicut on Friday night for Dubai and then came to Mangalore. The entire operation was done at night, during circadian low. His alertness level at the end of that 9-10 hour night duty surely would not have been very high," the pilot added. For the last three years, pilots of Air India, Indian Airlines and Jet Airways have been pushing for better pilot rest rules in India. Currently, the rest rules followed are the ones formulated in 1992.
Wow aa73- nice find.
Mandated smooth landings! Unbelievable. Some of the best landings safety wise have been solid touchdowns- there are so many factors that will necessitate a harderthan normal touchdown that this is truly nuts.
Not to hit close to home aa- but it reminds of the little rock passenger who was quoted- "it was a real nice landing though"....
If this is true- there ISA lot of blood on that particular mgmt's hands.
Any landing that you can safely walk away from and use the airplane again, is a good landing for me.
That's crazy! Hard landing or go around = carpet dance! It seems like you can't have it both ways. If you want to ensure a safe landing, then it needs to be stabilized and in the touchdown zone, but it might be firm - so then you have to explain yourself. OR, you let it float a bit for a greaser, but have to do a go around, and guess what? You've earned a trip to the CP's office!
My company actually said in a memo to just fly the profile and who cares if it is a hard landing. No one is going to be impressed if you have a tail strike or go off the end of the runway, or in this case crash and kill everyone!
Yep, unbelievable. AA has a huge push these days for go arounds if not stable by 1000' (in light of the recent KIN overrun and the other 2 incidents.) It's always been written that way in the flight manual but I guess some guys were trying to salvage bad approaches.
I'd like to know how one is supposed to predict when a touchdown will be more than 1.65G's?
I've had some doozies that I thought I was going to roll on.
If that is all true about the company policy on go-arounds and hard landings, I guess I hope those who made the policies get included personally in the each and every lawsuit filed against the airline for this crash.
Want to know how to land a 737? Let it auto-land. Boeing programs the airplane to hit the spot. It is not a greaser, it is safe and on target with no float.
You have wonder how these management guys think .They have 300hr FO's and don't let them get a leg. Must be fun when they get checked out at 3000 hrs and have made like 2 landings...
Some more scuttlebutt from pprune. Take it FWIW:
"I flew for AIE 2005-6 and can confirm that it was a dangerous outfit and a crash waiting to happen.They didnt understand flying and the guy in charge was a 777 pilot who knew nothing and cared even less of the 73 operation.They used the QAR unethically,busted FTL's and indulged in nepotism/favoritism even when it came to passing checks etc.
Like someone said already,as with all ASIAN carriers it was strictly rote flying;AP ON at 500 on TO,SOP call-outs verbatim(the be-all and end-all of their entire operation),AP OFF and AT disarm @ 500 on landing.No visual approaches(or maybe the type with AP and LNAV engaged!),magenta line monkey-see monkey-do flying.I remember they called a chap in after downloading the QAR for hand-flying without FD and warned him.I heard after I left that they started to tire of EURO-Yank expats and so brought in a whole bunch of Yugoslavs who were "easier" to mould to their way of thinking.GA's were ASR-mandatory.So is it any wonder that it all ended in a smoking wreck at the end of Mangalore runway?The real dilemna here is that there must be a a hundred AIE's operating around the world and the only thing that saves them from a smoking hole in the ground each and every week is the robustness and reliability of Boeing/Airbus products.Plus the fact that they practically fly by themselves and dont really need pilots up front but just 2 pavlov dogs..or better still,2 monkeys.Passing x feet,press that button there,passing y feet operate this switch here..."
