GasPasser said:Use both sources....I just checked the goang site and there is no info there about their SUPT boards. I'd say goang may be better for prior service folks. But if you are a SUPT hopeful, I'd use all available sources with baseops.net and goang as the two you should start with. Also, give the flying unit(s) in your home state a call. Do a Google on "ANG BRAC 2005", stay away from units loosing all their airplanes (duh).
Good luck! Go Guard!
I just checked out goang and found 3 A-10, 8 C-130, 4 F-16, 1 F-15, and 2 KC-135 units that are taking applications. On the main screen select officer vacancies on the drop down menu. You will find all the units that are hiring pilots there.
