dicko
"It's a formidable scent"
- Jun 7, 2007
Just like a French pilot always getting some nice tail.
Did you notice how quickly he stopped?
I wonder if the airport authority is not ending up being in the hot seat. As far as I remember staying on taxiway centerline guarantees you (wingtip) clearance of all obstacles. If the CRJ was indeed parked at a marked position, and the AF A380 was on centerline then it is time to take out the popcorn.
Regarding the French criminal case against CO, you do know that some "southern-style engineering" was applied to the DC-10, don't you?
I bet only one of those planes gets fixed, and the other goes to the scrap yard. The owner though (DL) may get some insurance money.
OYS
Maybe it's not this simple, but seems as though when you get an aircraft with the physical dimensions of the A380, an airport should make accommodations within the movement areas before the aircraft begins serving said airport.
If you have a taxiway adjacent to a ramp area, wouldn't you predetermine what sort of clearance you would need between the wingspan of an A380, and the aircraft in the ramp area? I assume this wasn't an unusual taxi routing for the 380, and that it is typical for CRJ's to be on the fringes of the ramp awaiting gates. Unless the CRJ was holding where he shouldn't have been, it seems like an airport problem to me.
From aim-
Ideally, the aircraft should be kept centered over this line during taxi. However, being centered on the taxiway centerline does not guarantee wingtip clearance with other aircraft or other objects.
You as the pilot are ALWAYS responsible for your aircraft. That AF captain is totally at fault.
YES and YES, the AF captain screwed the pooch or shall I say Poodle. You are in error applying a clearance rule for parked aircraft when the RJ was clearly not parked, just stopped.yes and no. In the FAA's paradise of aviation laws there's also a FAR that specifies aircraft clearances on taxiway to stationary objects (parked aircraft, buildings etc).
