Age 60 rule may change; you need to write your Senator
Andy
12/13/2012
The House passed HR 5576, an appropriations bill for the DOT, HUD, and District of Columbia. It did not contain any provisions to change the age 60 rule in it.
HR 5576 then went to the Senate appropriations committee for amendments prior to being voted on. While there, the entire text of S. 65 was added in Section 114 under Administrative Provisions -- Offfice of the Secrety of Transportation (link: http://thomas.loc.gov/cgi-bin/query/...sismU9:e379863: ) . This amendment is a back door way of getting legislation passed.
There is a way to have it removed, but it will require a Senator to object (a point of order can be made) to it once it is reported to the Senate. The bill has been reported to the Senate and is on the calendar under General Order Number 535. If the point of order is sustained (it should be, since this is a legislative rider on an appropriations bill), the bill will go back to the Committee on Appropriations. This is based on the Rules of the Senate, Rule XVI, paragraph 2. Link: http://rules.senate.gov/senaterules/rule16.php
In order to stop the change from slipping in through the back door, it will require an effort on your part to write, fax, or e-mail (in order of preference) your Senators to express your opinion. Since there is more resistance to the change among the Democratic party, I'd recommend writing Democratic Senators outside of you home state if you have the time.
Here is a link to all Senators: http://www.senate.gov/general/contac...nators_cfm.cfm
If you click on Web Form, it will usually take you to an e-mail form to send. If you click on the Senator's name, you will find mailing addresses and fax numbers.
On the Democrat side, I'd recommend concentrating firepower on Sens Inouye, Lautenberg, Rockefeller, Cantwell, Dorgan, and Pryor. http://thomas.loc.gov/cgi-bin/cpquery/?&dbname=cp109&sid=cp109S6pOz&refer=&r_n=sr225.109 &item=&sel=TOC_17092&
If anyone recommends any other Senator to target, please post.
Does this make any sense?
Dear Senator
Recently, the House passed HR 5576, an appropriations bill for the DOT, HUD, and District of Columbia. It did not contain any provisions to change the age 60 rule in it. HR 5576 then went to the Senate appropriations committee for amendments prior to being voted on. While there, the entire text of S. 65 was added in Section 114 under Administrative Provisions.
I believe that any changes to this long-standing safety regulation should be approached cautiously to ensure that any potential risk is minimized and commercial flight remains consistent with existing safety parameters.
As noted in the agency's testimony at a hearing regarding this matter, the FAA can not assure Congress that changing the Age 60 rule will maintain or raise the current level of safety. If Congress moves forward with legislation regarding the Age 60 rule, this matter must be adequately addressed prior to altering existing regulations.
As I believe this matter should be afforded the attention of the entire congress rather than slipped in the back door, I respectfully ask that you make a point of order regarding General Order Number 535 to have the bill sent back to the appropriations committee.
Thank you for your time
Sincerely,
