Amish RakeFight
Registered Loser
- Dec 28, 2005
Critical mach remains the same regardless of altitude. Mach crit is expressed as a percentage of mach. This percentage remains the same for a specific wing. Only mach itself differs depending on temperature and hence, altitude.
For instance, mach is achieved at a higher speed at lower altitudes and as you ascend in altitude (decreasing temp) mach will be attained at a lower speed. However, the percentage of mach at which mach crit occurs is fixed in relation to the mach number itself which will vary.
To quote my earlier post, critical mach is fixed in relation to mach itself which fluctuates based upon the temperature which varies upon altitude.
Technically, one could argue that critical mach changes with altitude and this is correct, if you understand that it changes along with mach itself. Critical mach rides the coat tails (if you will) of mach.
But as a limitation or milestone, Mcrit is recognized as a percentage of mach and only that. It does not vary on its own, independant of mach itself. It's variance is dependant upon the present mach's variance that which a specific wing is traveling at within a certain altitude.
