Advise on C182 highperformance sign-off
Alaskaairlines
Future Airline Pilot
Hey guys!
I know of a small flight school in Eastern Washington that I plan to go for the weekend to get my high performance sign-off.
Imo I believe I would be getting a sweet deal. The 182 just got a brand new 300 hp engine, and the solo rate is $65 and plus fuel. Thats a very reasonable price, right?
Well one question, what is the requirement for the Commericial rating in regards with a high performance aircraft, 200 hp or more? Any specific amount of hours I need?
The school also has a C150 that rents for like $30 an hour, solo. Awesome deals imo!
I plan on getting the sign-off and flying it around Oregon for a couple of days, whats the fuel burn like in a 300 hp C182? And what are fuel prices like around the Salem area?
Alaska,
No specific hour prereq's. Once you are signed off you are legal to fly. The real question comes when you ask wether or not the insurance company will let you fly it solo. When I first got my high performance checkout in a 182 I believe they wanted 5 hours. That was before insurance companies started clamping down so it might be much worse than that now.
The 182 is still a very forgiving cessna. If you were looking to get checked out in a 206 I would be worried. The 182 is, in my humble opinion, one of the most enjoyable flying airplanes which can haul a good load for it's size. Have fun and good luck.
I read your question again and realized that mabey you were asking what the requirments were for a commercial certificate. You don't need any high performance time, but you do need 10 hours of complex time. Therefore if the 182 you are being checked out in has retractable gear it could be used for commercial training.
C-182s
$65 per hour for a 182 is a decent price. That's what 172s cost wet here in Denver.
As I understand the rules these days regarding high-performance v. complex airplane signoffs, you can knock off both if you do them in a 182RG. If it is a fixed-gear 182, you only get high-performance.
One cautionary word: 182RGs, at least, can be an SOB to land properly unless you can move the CG aft. With two people in front only, more times than not you'll land flat. We used them at Riddle for Commercial-Single and CFI training. I almost always got flat landings. My students, who had their hands on the controls more than me, almost always got flat landings. However, when we had an observer in the back, the airplane landed just fine, as easy as a 172 or any other high-wing Cessna. Speeds in the pattern are about the same as a 172. I recall that 65 kts on final worked well.
Good luck with your checkout.
C182RG is the way a small single should be. Not only is it fast, but it actually can hold 4 adults with full fuel and baggage. Just remember to plan out your arrivals to the pattern and you'll be fine. It doesn't like to slow down.
There's no FAA-required number of hours for the sign-off for any level of pilot from private on up.
But you may want to ask the place what =their= requirement is for time in type before they will permit you to take the airplane solo.
Thanks guys! I talked to the CFI that instructs in it, and he said about 5 hrs to get signed off. Unfortunately its not an RG model.
I don't believe they have any real minimum.
Why would you be worried about a C206? Theres actually a C207 up in ANC that I can get checked out in! Its like $167 solo!
KSLE fuel is $2.34/gal according to:
www.airnav.com
10-12 gph in a C-182, so at your dry rental, you are paying $88.40 to $93.08 an hour. Depending on age you may have to kick in a quart of oil every so often, too!
Enjoy.
Do you guys know what a 182 holds for fuel, and what kind of range it has? Whats it average out for cruise in kts? 140-150?
Good point Iceman... can't say I have ever come across a 182 with a 300hp engine in it. Seen lots of other conversions though.
Obviously you would have to consult the engine manufacturer about the actual numbers, but you could go with the "pilot's rules of thumb" book...
Take the hp of the engine and divide by 2 and then divide by 10. that would come up with 15 gal/hr for your case, Alaska. That actually works pretty well for the singles i have spent time in. Of course this is just a rough gauge to get an grasp on things, but not for actual flights.
Thanks fellas, little pricy on the fuel part, but still way cheaper than I would be paying for one up North!
Its located at Martin Field, school is called "Fly by the Numbers". The city is College Place, which is basically Walla Walla, WA. Nice little uncontrolled farm airport, great fun!
If you need a signoff from a flight instructor to act as PIC of a high performance aircraft it would seem to follow that loging it as the PIC would only happen after that signoff has occured (after the flight). As was the case when my instructor signed me off.
You may not BE the PIC because you don't have the endorsement but you can log PIC because you are rated in the aircraft and are the sole manipulator of the controls.
Take care!
KnowledgeSeeker said:
If you need a signoff from a flight instructor to act as PIC of a high performance aircraft it would seem to follow that logging it as the PIC would only happen after that signoff has occurred (after the flight).
Only for those who have difficulty with the idea that "acting as PIC" and "logging PIC time" are completely different concepts and are subject to completely different rules.
Rule 1: If you are a recreational, private or commercial pilot, you may log PIC any time you are the sole manipulator of the controls of an aircraft you are rated for.
"Rated" means the category and class (and type, if a type rating is necessary for the aircraft) that is listed on the back of your pilot certificate. Nothing else matters. Not instrument ratings. Not endorsements for high performance, complex, tailwheel aircraft. Not medical currency. Not flight reviews. Not night currency. Nothing.
Acting As PIC = duty, authority, responsibility
Logging PIC Time = putting numbers in columns on a piece of paper
Different purposes, different concepts, different rules.
