piginshlitz
Member
- Nov 4, 2003
Fromage said:Well, if the aircraft was an Airbus, the accident would not have happened because it stands taller on its landing gear and is therefore safer and able to look down upon other aircraft.
Fromage said:Well, at least I do not support places like Air Tahoma!
Ben Franklin said:Have the frogs learned how to go around yet(it's alot like surrendering, so I figured that they'd have it mastered by now)? or are you dumbfukcs still putting airbuses in the forest at airshows?
http://www.alexisparkinn.com/photogallery/Videos/B-52%20Crash.mpg
Dick.
Sincerely,
B. Franklin
white E said:Didn't someone else get killed there a couple of years ago? Prop??
328dude said:LearLove? Was that your flight buddy?
LearLove said:It was a MidAtlantic ramp worker. She drove the beltloader into the side of one of our 170's and was crushed (wedged) between the fuselage and the ramploader. I was there shortly after it happened. I know the FO and the Capt, they were onboard when the accident happened. They felt/herd the loarder hit the plane and the Capt rushed out to find the result. It sounds like she died on impact.
From hearsay around the ramp she was pretty new (a few months) and was a single mother of 2 (the last sentance is what I was told around the ramp).
The Piedmont accident that some are referring too happened in the summer (July or August) 2001, I want to say July if I remember correctly. The ramper had removed the chalks from the front wheel of the Dash and tossed them off the the left of the plane (if you were looking at the dash standing infront). The chalks did not go far and were in the track of the right side main gear on the Dash so he ran to pick them up and move them further off to the side but as he ran foward and bent down to pick up the chalks he kept going fwd and ran bent over into prop which had just been taken out of "start-feather". The dash had not yet moved. The result was not pretty.
WMUSIGPI said:Well we all now know the latest incarnation of TabExpressFO (Fromage). Time to boot this douchebag. Isn't there a way to disallow new screen names from his email address so we don't have to put up with this anymore?
