airplane wizard
- Mar 30, 2006
He is the airplane wizard after all, maybe he can figure it out.
Since most 320 family Airbus have stick shakers he is probably right...idiot.
I don't know... how are you warned of a stall on your copy of MS Flight Simulator?
It is imposable to stall a 320 family Airbus operating in NORMAL LAW.
The airbus can stall in normal law.
Have you ever flown at flaps full alpha max and then retracted the flaps? I wouldn't try because it only prevents the slats from retracting (alpha lock)
Also..full rudder in one direction followed by full rudder in the opposite direction is not approved and would cause a stall at low airspeeds.
You can however stall a 320 in any law other than NORMAL, if you approach a stall the AWU will yell STALL, STALL, STALL.
You do know 320/330/340/380 Airbus have only side sticks, and they are not interconnected.
What if you trimmed full nose up, then shut both engines and all electrical power/APU/batteries off? Would it stall?
I flew into Denver last week and it only showed 125mph on final approach on the direct tv gps map. Do they fly final at stick shaker to save $ on brakes?
Why on earth would anyone even wonder about doing that?
It's not that difficult to figure out. Depending on weight the vapp speed is in the 130's indicated. You were reading groundspeed, so you were landing in about a 10 kt headwind. Not that unusual.
But if the Vref is 130 knots, 125 mph works out to be about 105 knots if my math is correct. So given a 10 knot headwind, the ground speed would be 138 mph (130 kt-10 kt head wind =120kt *1.15=138mph) Ok, I know the speed on direct tv doesn't update instantaniously and may not be that accurate to begin with, but I was just curious what some of the Airbus pilot's would say about it. Thanks guys.
....Realy. AB AC have "stick shakers"....Better study-up for your next oral DA!!!..The only STICK SHAKER in the Airbus is during LAV BREAKS!!!
