A new Twin
Flyin Tony
Has anyone seen the Gemini CH 620 from Zenitair www.zenithair.com It looks real nice cant wait tell the Kit start selling. Im going to try and talk my Pops into one.
some spec off there web.
SPECIFICATIONS
LENGTH 19 FEET
HEIGHT 5 FEET 10 IN.
WINGSPAN 27 FEET 3 IN.
WING AREA 123 SQ.FT.
WING LOADING 11.8 LB/SQ.FT .
POWER LOADING 9.0 LBS/HP
SEATS 2 SIDE-BY-SIDE
CABIN WIDTH 44 INCHES
EMPTY WEIGHT 800 LBS
MAX GROSS WEIGHT 1450 LBS
USEFUL LOAD 650 LBS
FUEL (STD) 34 US GAL (205 LBS)
ENGINE JABIRU 2200, 4-CYL., 4-CYCLE, AIR COOLED, DIRECT DRIVE
POWER 80 HP (60 kW) @ 3300 RPM
DISPLACEMENT 2210 cc
IGNITION DUAL IGNITION, BREAKERLESS TRANSISTORIZED
STARTER ELECTRIC, 12 V
FUEL CONSUMPTION 3.75 GAL/HR 14 l/HR
PROPELLERS FIXED PITCH, 55-IN DIAM., GROUND ADJUST
If they start making the Kits I think we might have some twins at a 172 price
Note, they have talked about this since 1997. Since then, there has been no development. Their focus is on Sport Aircraft, not the twin. Not the first time a plane has been announced, a prototype created, and then disappeared.
Dang
I knew that they have yet to make the Kits yet
But its been around from 1997.
They not going to make it then. Im mad
Don't hold your breath. That company is very flaky. I started a CH601HDS from that company. What a joke aircraft that was. Hand written notes on the drawings, over stated performance numbers, etc, etc. So I built an RV instead!
I would expect to see one of the under $1mm jets first. Sometime around 2012 to 2018.
