I agree that flaps would be a bad option for you, but why do you need to descend quicker than 1500 fmp??? If you get to your level-off altitude & have to push up power, you got there at least somewhat early; if it looks like you'll be droning at 4000' for a while, why hurry down with the S/B so you get there sooner only to then push up the power (sooner) & burn more gas? The 737 will only do about 1200 fpm at 210, or about 1600 at 250, and it's rare that we need to use speedbrakes in most terminal areas. Sometimes it happens, or sometimes it's useful (abeam the field at 10,000, cleared the visual #1), and cases like that toss out all the drag you got and play the speed & distance so you push up power for a stabilized approach but not miles sooner.The CRJ will not descend at a decent rate (say at least 1500 fpm) and stay at 210 KIAS. My choices are: pick a slower descent rate, flaps, flight spoilers or some combination of the three. I choose spoilers. Why? Because I'm 30 knots faster than min clean and I don't need the flaps for safe maneauvering. When I level at 4000 I'll need less thrust to maintain speed and altitude clean than I would with flaps 8 or 20.
While they may not like 500 fpm..There is nothing wrong with it under most circumtances..Thedude said:Man I wish the controllers in the JFK area
thought that anything over 500'fpm was gravy.
Good point. I almost never use the boards on the EMJ. I plan my descents in VNAV at 3200FPM, and descend idle at about 3700FPM, which gives me a little lead time to initiate a smooth level off.English said:The use of speedbrakes is a crutch to cover for bad planning, either on ATC's or the pilot's part. It's bad form, IMHO. I learned when flying corporate that passengers hate it and are very uncomfortable with it. Now that I know that, I NEVER use them unless absolutely necessary. I think I've used them twice and hated every second of it. The 737 descends just fine under normal circumstances without them.
Now when I fly in the back on other airlines, I wince whenever the speedbrakes come out. Some guys actually add power with the speedbrakes out...I don't get it. I guess power management and efficiency are lost on some.
Is there really ANY way to deploy them smoothly? The spoilers on a Lear are truly a terribly designed system. I always wondered why there wasn't a neutral "off" position in addition to extend and retract so you could just crack them a bit...One of the benefits ive gotten from flying Lears in both the cargo and passenger business is both an appreciation for and dislike of speed brakes..
Passengers hated them and I didnt like the large pitch change/stick forces needed to deploy them smoothly..
Yes..With lots of practice you can..F/O said:Is there really ANY way to deploy them smoothly? The spoilers on a Lear are truly a terribly designed system. I always wondered why there wasn't a neutral "off" position in addition to extend and retract so you could just crack them a bit...
TIS..TIS said:MLBWINGBORN
You may not agree with what the controllers have in their handbook about what we can or cannot do but you DO have to live with it. You see, it's the ONLY thing they have upon which to base their decisions about how to handle IFR traffic (other than experience, which can't be counted upon with less than fully qualified controllers), and because it's published, a judge can read about it. If a controller winds up testifying that he thought you were going to handle the airplane a particular way based on the only published guidline he has for assuming such, the judge will read the same thing the controller read and turn to you with some tough questions to answer.
I'll bet you believe, as we are all taught, that you have the entire runway when you're cleared to land, don't you? Well, I've got some bad news for you. You don't! I'll bet you didn't know that pilots have been sucessfully violated on a 91.23 (failure to adhere to ATC instrcutions) because they did not make a turnoff from a runway they were told to make? It's true. It's happened several times and the reason it's happened is because controllers have it in their book that we should only need the first two-thirds of the runway to land. They are told this so that they have a guideline to help them with runway spacing decision-making.
So you see, there's a problem that can arise from the difference between what pilots are taught about handling airplanes and what controllers are taught about handling airplanes. In this scenario, the result is that if you're not off the runway, or if it's apparent that you won't be and they need you off because of their planning, they'll start barking at you to keep it moving. If you don't do it and it creates a conflict, they're going to offload their troubles on you for failure to comply.
It doesn't matter what you do or do not know about their book once it goes to court. The judge will determine that, as with many situations in which supervision is required, sometimes there isn't time to ask 'why'. You must simply comply and ask questions later. The FAA lawyers will have a very easy time proving that you didn't comply and that's all it takes to lose.
I say all this to make the point that you might not like what ATC expects, or the basis upon which they rest their assumptions, but the FAA lawyers WILL hang their collective hats on things that you do not know if it makes a difference in whose face the egg winds up on.
I can tell you that if you try to tell a center controller that the optimum rate of descent for your 737 is 500'/min., no matter what the circumstances are, when you're asked why the slow descent rate it's not gonna be accepted. I can also tell you that if a conflict results from YOU not doing what the controller knows he can reasonably expect, you're going to get a phone number to call about a possible 91.23 pilot deviation. Rates in excess of 500'/min are, therefore, not simply "gravy."
If you truly need to descend at a rate like that then you need to advise the controller. Now you might not think so because it's not an expressly required report per the regualtions. It is however, an implied required report. It comes under the catch-all heading of "pertinent to the safety of flight," which you ARE required to report . The term 'safety of flight' HAS been legally interpreted so that it can apply to things occurring outside YOUR airplane. In other words, safety of flight isn't just about YOU and you must anticipate the probable effect of your handling of the aircraft if that handling differs significantly from what is normal. What's normal may well come down to expert testimony in court but is that realy where one wants to end up? If you're doing something unusual or if your operating requirements might affect the way ATC plans your handling, you need to let them know - it's just common sense.
I know you and probably quite a few other people out there will see this as splitting hairs. Fine. See it that way. It doesn't make the assertion that it's completely up to you how you operate the aircraft any more true. There ARE times when the phrase, "Work with me here," applies to the pilot.
As a PIC your job is to operate the aircraft safely. A controller's job is to keep aircraft far enough apart to meet safety standards. When those two jobs are at odds it does not relieve you of your responsibility to work with the controller so that both jobs ARE done without conflict. In other words, it's not your job to dig in your heels and isolate your job from his.
TIS
The Dunlops are the best to slow down if you have to in a hurry. Otherwise, not to often. Previous posts on planned descent are pretty much right on, in using the vnav.
Guppiedriver said:I think they're Michelins.![]()
