731 engine
jimmyw
Total Time
5000
I forget the reason that up in the high flight levels that idle flight N1 is somewhere near 70 - 73 % and down low 20 -30 %.
Also does it matter that the fan turns when the plane is parked for extended periods? I know engine covers do the trick but I've heard some in the know who say there is minimal if any wear on bearings in this free spin in wind scenario.
Fly91
Registered Pilot
Total Time
lots
I was told the accessory drive still rotates and is not lubricated when the engine is not running, so its bad.
And I don't see why fan blades need to continually be smacking the inward and outward stops for hours and hours. That is wear and tear. Fans b;ades are not supposed to move like that for hours.
LJ45
Total Time
13,000
You would need a hurricane to turn the N2 and drive the accesories on the ground, you are wrong there!
LJ45
Total Time
13,000
A couple of reason they idle higher at flight levels is to prevent flame out and to provide proper bleed air.
Fly91
Registered Pilot
Total Time
lots
Yeah, I was told that but didn't know. I wonder what turns from the fan shaft turning. Inside the turbine shaft wouldn't be lubricated either.
LJ45
Total Time
13,000
there is enough residual oil to not cause a problem in the short term.
TransMach
Total Time
>12K
QUOTE
ENDQUOTE
Reason #1 - The computer is programmed to raise the idle speed as altitude increases so that the engine will make minimum spool acceleration required by certification. Turn the computer off at altitude and the engine will slow to min-idle fuel flow.
Reason #2 - Min-idle fuel flow as physically set and will result in a higher idle speed at altitude than at sea level due to the reduced drag of a higher density altitude.
Reason #3 - That's what Garrett wanted to do!
TransMach
