3 big myths about Delta's Refinery---article
General Lee
3 Big Myths About Delta's Refinery
By Adam Levine-Weinberg Motley Fool
February 8, 2013
Delta Air Lines took Wall Street by surprise when it decided to purchase an oil refinery in Trainer, Penn., from Phillips 66 last year. Since then, many observers have criticized the deal, arguing that Delta's refinery strategy is doomed to failure. However, much of the criticism is based around three big myths. The truth is that Delta's refinery gambit will probably succeed.
Myth No. 1: If Phillips 66 couldn't make it work, Delta can't either
Perhaps the most common criticism of Delta's refinery purchase is that the company should not expand beyond its core airline business. Phillips 66 had idled the Trainer refinery prior to selling it and was unwilling to make the necessary investments to keep the refinery running. As the largest independent refiner in the U.S., Phillips 66 clearly has significant expertise in refinery operations. Thus, many industry observers believe that if the Trainer refinery would have been a bad investment for Phillips 66, it will be an even worse investment for Delta.
This overlooks a key insight from modern portfolio theory. Investors should demand a higher return for accepting less diversification, and thereby taking on more risk. For Phillips 66, which already owns 15 refineries, owning a "marginal" refinery adds risk that cannot be justified by the expected returns. If the refining crack spread (the price difference between a barrel of crude oil and a barrel of refined products) were to drop, the Trainer refinery would likely become unprofitable. Instead of investing money in the Trainer refinery, it made sense for Phillips 66 to sell it for $180 million and use the cash to fund capital expenditures at other refineries, and to return money to shareholders.
By contrast, for Delta, owning a refinery allows the company to hedge against an increase in the market crack spread. While the refinery subsidiary (Monroe Energy) could lose money if the crack spread decreases, Delta would still benefit in that scenario, because a lower crack spread translates to lower jet fuel prices (holding crude oil prices constant). Thus, owning a refinery could potentially reduce Delta's risk through diversification, which explains why Delta is willing to operate an asset that Phillips 66 wanted to divest.
The only remaining risk for Delta is that operating costs for the refinery come in higher than projected. However, barring unexpected maintenance issues, I assume that the long-term costs of operating the refinery can be projected fairly accurately. If Delta did its due diligence before acquiring the refinery, this should not pose a problem. The refinery is being overseen by a 25-year refining industry veteran, so the plant is likely to be managed competently.
Myth No. 2: Delta should just "hedge" instead of owning a refinery
Some people have responded to the diversification argument by claiming that Delta could just "hedge" using financial derivatives. However, this argument is based upon a fundamental misunderstanding of the problem. Delta already hedges against changes in the price of crude oil. By contrast, the Trainer refinery acquisition was designed to help Delta hedge against changes in the crack spread.
It is much more difficult to hedge against changes in the jet fuel crack spread. Jet fuel swaps are the only way to fully eliminate the risk of fuel price changes, but these instruments are expensive, illiquid, and not typically available in sufficient quantity for an airline of Delta's size. Instead, airlines often use derivatives tied to New York heating oil, which is an exchange-traded commodity. However, the correlation between jet fuel and heating oil is far from perfect. For example, the premium of Gulf Coast jet fuel over New York heating oil dropped from $0.109 per gallon to $0.018 per gallon from 2008 to 2009. More recently, the premium has been around $0.05. These fluctuations show why hedging with heating oil derivatives is not fully satisfactory. The best way to minimize volatility in the jet fuel crack spread is to own a refinery.
Myth No. 3: Delta's refinery loss last quarter proves that the acquisition is a failure
The website EconMatters posted an article last week which claims that the Trainer refinery acquisition was a mistake. In addition to making the standard argument that Phillips 66 would have kept the refinery if it could have been profitable, the author also points to refinery losses of $63 million in Q4 as evidence that the acquisition has failed. However, the refinery was just restarting operations during Q4, and Hurricane Sandy severely disrupted distribution operations. While the Trainer refinery was able to keep operating through the storm, products could not make it to market. This forced Delta to slow refining rates, which hurt efficiency, and also resulted in some damage to the fluid catalytic cracker, which then had to be taken offline for repairs.
Nevertheless, these disruptions were all one-time events that should not recur. On Tuesday, Bloomberg reported that the Trainer refinery may be ready for restart later this week. Moreover, while EconMatters erroneously stated that Delta expects a small loss at the Trainer refinery in Q1, Delta actually stated that it expects a modest profit.
Profitability should improve even further in future quarters for three reasons. First, the fluid catalytic cracker has been shut for more than a month, which will depress Q1 profit, but not future quarters. Second, Delta will do test runs of Bakken crude brought by rail during the spring. If the test batches work as expected, Delta will be able to meet a significant amount of its crude oil demand with lower-cost Bakken crude. Phillips 66 recently embarked on a similar strategy, signing a five-year agreement with Global Partners to deliver Bakken crude to its Bayway refinery.
Lastly, Hess recently announced that it will close its Port Reading refinery this month. With less available refining capacity on the East Coast, the supply of refined products will be smaller. This reduction in supply has already boosted the crack spread (the premium of refined products over crude oil). Since the Trainer refinery's operating costs are relatively fixed in the short term, this increase in refined products prices has improved the refinery's profitability.
Conclusion
Investors should not be scared by the myths surrounding Delta's refinery operation. Delta's management continues to project strong refinery profitability for 2013. Given that the company has outperformed peers for the past several years, investors have no reason to doubt management's competence. Alarmist reports about the refinery's profitability do not tell the whole story. Several years from now, the Trainer refinery purchase will likely be seen as a big coup for Delta.
But hey, Andy and Redflyer probably disagree, so this may all be moot.
Bye Bye---General Lee
Myth No. 4 - General Lee's cheerleading in this forum makes a difference or means anything to anyone.
I fully agree with the author on point 2; there isn't a good option out there to hedge Jet A crack spreads.
For what it's worth, the author is a HUGE Delta fanboy; this is at least the third article he's written on the virtues of the Trainer purchase.
http://seekingalpha.com/article/852321-delta-s-refinery-buy-looking-smarter-every-day
http://seekingalpha.com/article/101...looking-even-better-thanks-to-hurricane-sandy
I'm refraining from final judgment on the Trainer purchase until 2014. That should be long enough to make it work.
Only 3 more posts until Lee hits 17,000, kiddos!
My bet is 18,000 will be before the end of Feb.
I read somewhere that recently, the price of idle facilities has tripled as a result of Delta's purchase. That says to me they did the right thing and industry people have figured that out.
I agree. If your number 1 cost is fuel, it's only logical you try to hedge thru ownership.
Time will tell.
DAl skrewed up, they shoulda harnessed Jenny p's mania fueled posting frenzy.
Moooommmmmm. The meatloaf!
Andy,
It's good you will reserve judgement until 2014, but if disagree with Fanboy's #1 and #3 reasons, then give reasons why you disagree. I'd like to know.
#1: He erroneously applies Modern Portfolio Theory (MPT) to corporations. MPT is for individuals, not corporations.
Applying his use of MPT to another Delta consumable, beverages, perhaps Delta should start manufacturing the onboard drinks? They don't because economies of scale apply to the manufacturing process.
#3: While I gave Delta a pass on Trainer's Q4 performance and will give them a pass through 2014, there comes a point in time where they either figure out how to operate the facility profitably or they should throw in the towel.
The author's argument that Hess' decision to shut down their Port Reading facility will reduce supply and drive up crack spreads is incorrect. The Port Reading facility is only able to process cracking feedstocks, not crude oil. In other words, it would require major upgrades to process crude oil. So what about the cracking feedstocks that it won't process anymore? Other refineries have been upgraded to process higher volumes of feedstocks into refined products. There are a lot of refineries in the US undergoing upgrades to not only produce additional refined products but also to process higher concentrations of heavy sour crude. (The Philadelphia Sunoco/Carlyle refinery is just one refinery being upgraded; there are two new refineries proposed to be built in North Dakota). That's important because light sweet demand is outstripping supply while heavy sour is not in as high demand.
A major obstacle for the Trainer facility is shipping costs to the facility. If they can find a way to have crude delivered to Trainer at a lower cost than shipping by rail, there's a good chance that the project will be financially successful. I don't rule out that possibility.
I'll have to say that Andy got it exactly right. I agree with giving the venture some time to play out. SW looked into the same move a little over ten years ago and the numbers didn't support it. But I'm sure they will be watching closely.
The friction of just getting the crude from ND is going to be hard to overcome. Other refiners have already run the numbers, then shut down once they saw those numbers. The author of this article didn't even mention that aspect. More of a PR piece instead of objective journalism.
I've always said it would be interesting to watch it play.
Thanks Andy for your hearty reply. I "believe" management thinks shipping the crude via rail from ND may be cheaper than crude at Brent Crude prices from Nigeria, so maybe that is their thinking. If you save a buck per gallon, or whatever, maybe it is worth it in the long run. As you and Red say, it will be interesting to watch. Thanks again.
If Bakken (or a Canadian light sweet crude) could get to Trainer via pipeline, the facility would almost certainly be profitable. Since there are other refineries in the general area of Trainer that would also benefit from a pipeline, we may see an announcement within the next year that a pipeline will be built.
