2nd Segment Climb - % Just Makes No Sense
AZ Typed
Hobby's Flyin
Alright. I've had enough. I'm confused and I need help. I do not understand the 2nd segment climb requirements, especially since I can't find any airport charts that list climb gradients as a %. I've tried to teach myself - but I'm missing something very basic and doing more harm than good at this point.
Do you know of any good books / reference on this topic out there?
I'm confused in how to figure it out, what it gives, when it's a factor (I think I know that one, but who knows), why it's important (think I know that one, too...but likely somebody knows better out there). Any insight into this confusing topic would be greatly appreacited!!!
Humbly...AZT
Humbly...AZT
I have a great manual that explains all that performance stuff very very well and puts it in plain english. When I get to the hangar tommorrow I will type out what it says for your clarification.
Don't feel bad. If you dont have to deal with that stuff almost monthly or even weekly it is very easy to forget or get confused with.
A good short cut if you need to convert the "Ft/Nm" to a gradient is to use the "Gradient to Rate" Table in the front of the Terminal section of the Jepps, take the ft/nm on the left and then go across the ground speed columns to the 100 column, the number in that column is your gradient X 100.
Example; 200 ft/nm = 333 (3.3%)
Or you could do the math; Rise/Run X 100
Where Rise = ft/nm, Run = 6,000 ft (1nm)
Example; 200/6000 x 100 = 3.3%
Thre was an excellent thread on this recently...just can't remember exactly where it is. The subject was covered in detail with masterful contributions by leadsled.
