FarginDooshbahg said:Exactly. A Metro is way more airplane than a 1900 ever thought about being, and there are numerous companies that operate THAT single pilot.
What makes the Metro more of a handfull? Systems? Small wing? Bad single engine perf?
1900 single pilot? no big deal, have over 1500hrs single pilot experience.Flyin Tony said:That looks like alot of plane for one guy
KeroseneSnorter said:Nah, Just a long King Air thats all.
I.P. Freley said:Is there anything the person in the left seat can't reach and REQUIRES a second pilot?
KeroseneSnorter said:unless you can fly and get up and go over to the breaker panels at the same time I would call that needing two pilots.
I.P. Freley said:I thought that's what the autopilot was for....
KeroseneSnorter said:.
Cessna tech told me that the XL was originally designed with SP ops in mind but the lack of visibility shot it down. I think one of Simuflites sims is one of the first built and has the gear handle on the left side. something that no XL was ever produced with.
Groundpounder said:Wrong. Here are two examples. It was up to the buyer where the gear handle, RTU's and MFD is placed in the cockpit.
http://www.airliners.net/open.file/743808/M/
http://www.airliners.net/open.file/566522/M/http://www.airliners.net/open.file/566522/M/http://www.airliners.net/open.file/566522/M/
KeroseneSnorter said:If auto pilots always worked and never failed or popped breakers, then you would have a good point. And then we could get rid of half the airline pilots in the country.![]()
FearlessFreep said:The most fun thing in the Metro III flying single pilot was taking off High & Hot (Toluca, MX) with the water/alcohol injection...
You're right on about the CAWI system. Nice kick in the pants on takeoff with the extra 100hp/side.
Lots of people can't believe we fly the Metro single pilot. Honestly, it could be a handful....if you're complacent, but that goes for anything. In reality, it's just another 402 or Navajo after a while, with a few more gadgets to mess with. I remember when I thought a Tomahawk had a lot of gauges...you get used it.
siouxicide said:In reality, it's just another 402 or Navajo after a while, with a few more gadgets to mess with. I remember when I thought a Tomahawk had a lot of gauges...you get used it.
I.P. Freley said:All I remember about the Chieftain I used to fly was the fact that if you had an engine failure, you had negative climb performance on a hot day at max weight..
