SneakyJake
- Jan 4, 2004
Searched, couldn't find it. Does anyone know of the legal ramifications of going over a 16 hour duty day while you are following the ALPA guidelines? Can you be violated? I hear rumors of people diverting midleg, don't know the details.
Q-21. How should I calculate my ETA to ensure I do not go beyond 16 hours?
A-21. The following examples detail the required calculation:
Step 1. Determine the time you signed in for flight duty or
became available for a reserve assignment.
Step 2. Add 16 hours to that time to determine the maximum
duty day.
[Note: if your duty period exceeds 15 hours, your FAR
“look-back” rest is 8 hours – you must have compensatory
rest at destination.]
Step 3. Before you depart the gate on each flight segment,
you must calculate whether you will arrive and be released at
the destination airport so that you can “look back” 24 hours
from the release time and find at least 8 hours of rest. In
determining your arrival time, you must consider actual
conditions, such as weather, ATC, ground holds, or any other
known delays. If you estimate you cannot reach the
destination and at release meet the look-back provision, you
should not depart the gate, even if you were legally
scheduled.
Step 4. If you estimate at the gate that you will arrive at the
destination and be released in time to comply with the lookback
requirement, but you have an unexpected ground delay
prior to take off so that you will not arrive in time to comply
with the look-back requirement, you cannot take off and must
return to the gate.
duty day.
scheduled.
return to the gate.
