135 vs. 91 Question
starcheckdriver
If an owner of an aircraft management company decides to fly on one of the aircraft his company manages, but does not own the particular aircraft, is that flight considered to be Part 91 or Part 135?
MANUAL or POI!!!!!
I believe it is PT. 135,although this should be covered in your "manual",if not ask your POI!!!!!!
It really depends on how the management contract is written. From the ones I have read, there is usually a clause to cover that, making it a Pt 91 trip.
And don't ask your POI, he doesn't know either. He will just make up something. For legal type questions always ask FAA Legal for a letter of interpretation for an answer that has some legal standing.
You might be able to call it a trip incidental to the owner's business. Also, depends on type of airplane. Read Part 91 Subpart F - specifically 91.501(b)(4). NBAA has a small aircraft exemption that allows aircraft under 12,500 (i.e. King Air) to use these exemptions.
If you want to get technical, I would argue that it doesn't matter what you write in the management agreement if it contradicts the FARs (I'm NOT a lawyer by any means).
IMHO, there is always a way to make these flights Part 91.
Hope he asks the owner of the a/c first before he "decides" to fly on one he doesn't own. If he pays, isn't it almost always part 135 unless their is a "time share" arrangement in place.
No Problem with free legal advice here......But you usually get what you pay for.
A 135 aircraft made a "bad" landing a couple years ago at OKC and the FSDO did a records check only to find a bunch of part 91-ish flights. Several pilots had certificates suspended. Are ya feeling lucky???
http://www.l-lint.com/articles/use-of-a-special-purpose-entity-for-aircraft-a-tra/
Airplanes are a fact of life in modern business. They provide senior management efficiency, safety, and security. Nevertheless, they are also a source of worry for corporate counsel and the risk manager. They expose the company's assets to significant liability in the event of an accident and their appearance on the company's balance sheet may incite stockholder unrest. To avoid these problems, creative corporate counsel often decide to set up a special purpose "flight department" entity with no assets other than the airplanes and no purpose other than their operation for the business of the parent company and perhaps other subsidiaries as well. Of course, paying for the operations of this entity requires funding in some fashion by the parent or other subsidiaries. With this structure in place as a shield against plaintiffs' lawyers and disgruntled stockholders, the CEO and General Counsel sleep easily. But should they?
According to the FAA, business aircraft may generally be operated under the noncommercial rules in Part 91 if compensation is not involved. However, if compensation is received, the FAA generally requires the operator to obtain a certificate and comply with the more stringent rules in Part 135. To the FAA, anything of value (even accounting charge backs between affiliates) represents compensation. How does this affect our "flight department company?" After all, it only flies for its parent company and affiliates, receives no cash for flying, and is never expected to make a profit.
FAA rules do permit a subsidiary company to fly an airplane carrying executives from its parent company or other subsidiaries of the parent under Part 91 without obtaining an FAA certificate. These rules even permit recovery of the costs of the operation. However, the FAA insists that this flying be "incidental to and within the scope of" some business other than transportation by air. Unfortunately, our "flight department" subsidiary has no business except transportation by air.
The FAA Chief Counsel has issued a legal interpretation saying that a company with no business other than operating a flight department may not fly under Part 91; rather, it must obtain an FAA certificate and comply with Part 135. The FAA has also made it clear that if it discovers a "flight department company," it may bring enforcement action against both the company and its pilots. The company can be penalized as much as $11,000 per violation and the pilots may lose their licenses. Not a happy result and now the CEO is asking his lawyer some hard questions.
An FAA violation is bad enough. Is that all that can happen? Unfortunately not. First, flights within an "affiliated group" are subject only to the federal excise tax on fuel used. With proper tax planning, flights outside the affiliated group (such as brother/sister companies) can also be subject only to the fuel tax. However, use of a flight department company will subject all flights outside the affiliated group to the "ticket tax" of 7.5% on all amounts paid for such transportation. These amounts could include intercompany charge backs or contributions to capital.
In addition, aircraft may often be acquired free of any state sales or use taxes. However, the use of a flight department special purpose entity may otherwise undermine good sales and use tax planning.
Finally, in the event of an accident, this structure may increase liability exposure-exactly the opposite of what was intended. If the FAA or the NTSB determines that the flight should have been flown under Part 135 instead of Part 91, a plaintiff's lawyer may be able to use this finding to bolster his case for liability. In some states, it may also help to "pierce the corporate veil" of the flight department subsidiary to get at the assets of the parent. Finally, some insurance policies cover only noncommercial operations, or exclude operations in violation of FAA rules from coverage. If the FAA determines that the flight department company failed to comply with Part 135, this may open the door for an insurance company to deny coverage.
Are there alternative structures that can avoid all these problems and still provide some comfort for the CEO and his lawyer? Yes, there are. Selecting the right one requires careful analysis of each particular situation. However, with the help of an experienced aviation legal team, the right choices can be made. Call an aviation lawyer-you'll be glad you did!
I have an e-mail into L&L asking for their source for the Cheif Legal Counsel's opinion. Will post it when/if I get it.
I've spoken with a few aircraft management company owners and they are not too pleased with this...
This has been around for a long, long time and any attoreny specializing in FAA matters will tell you these are the rules.
Most people mess it up and hope the FAA doesn't come calling. Risky business.
Hi!
The flight is -135. However, LOTS of owners, companies, pilots, and FAA officials look the other way and pretend that these and other -135 flights are -91, and there is no problem.
If you get caught/incident/accident, you are screwed. If you don't fly the flight as -91, you might get fired. Nice!
cliff
NBO
This relates more to an aircraft holding company to manage or "hide" the airplane & expenses. That company's only business is the airplane and therefore trips for the "parent" company would not be incidental to the holding company's business.
Not remotely enough information has been given to discuss the matter. You're going to need to be a lot more specific than that.
Hi!
cliff
NBO
135 regs and the extremely selective enforcement of them by the FAA are the single most employee unfriendly thing I've ever encountered.
