121 question
Peace
Active member
i wanted to ask another question does a PIC have to have a line check in each type?
Line check once a year (my company's training regiment), in the aircraft that you are currently flying. Some airlines I believe require one every six months.
121 Regs
Once per year for a Line Ck is the what the regs require, a company can put in its manual anything wants as long as it meets the FAR minimum. Now for a PC you must have a check every 6 mo, or training in place of one check.
To answer the question which was actually asked: No, you do not have to have a line check in *each* type aircraft, just in one of them. However, PIC qualification in more than one type is relatively uncommon in the 121 world.
§121.440 Line checks.
(a) No certificate holder may use any person nor may any person serve as pilot in command of an airplane unless, within the preceding 12 calendar months, that
person has passed a line check in which he satisfactorily performs the duties and responsibilities of a pilot in command in one of the types of airplanes he is to fly.
