121 ATP written
need2AV8
The ATP written Gleim has several different chapters/planes for weight & balance. From what I've heard, the 135 version of the test draws from different chapters/planes than does the 121 version. Can anyone out there confirm which planes are used for the 121 test??
Thanx,
When I get the book, I'll check it out...
The only questions to be omitted from the 121 test are the 135 regulation questions. All 135 XC planning will be in the question bank for the 121 test. I had one for a C208 and a G2.
I just took it at AllATP's at it went fine. The 300 bucks is well worth it. You study 8 hours. Not a month. I got in the middle 80's. The proctor said that most people get between 85 and 90.
Props
Props,
A question for you - exactly what is it that AllATP's does for $300? Are you sitting at a computer studying questions for 8 hrs? If so, couldn't you do that at home for free + price of test (about $70)? I never quite understood what it is that they offer.
Well they cut the ? bank from 1515 ?'s to 558 ?'s. It is the bank that the FAA uses for the test. There are about 3 to 5 ?'s that ATP does not have. If you want to take it there i will look up the ?'s and let you know.
Props
