I've been using Anywhere Map with WX for the past 3 months and I can't imagine flying without it! There's nothing like having weather in the cockpit! Not just radar pictures, but METARs and TAFs as well. One time my destination was fogged in at 500 RVR. I knew about it more than 100 miles away and that I would need to come up with an alternate. Anywheremap uses color coded boxes displayed next to the airports to denote ceiling and visibility. Red over red means IFR, Maroon over Maroon means hard IFR (close to or below minimums), yellow over yellow MFR, etc. Then you can just click on that box and it gives you the actual METAR right there. Very easy to use. All I had to do is zoom out a bit til I saw something better. I found an airport 40 miles away that was red over yellow and was able to shoot the approach in. Funny thing was I had more and better information than ATC had! ATC had no idea what the weather was at that alternate. I told him, no problem I've got it right here.
As far as NEXRAD goes, it just gives you a little bit more comfort especially flying night IFR. You know that you're not about to fly right into level 4 stuff. If you see it, you can just ask ATC to deviate. A lot of times, they are too busy or just don't care to deal with you if you don't have onboard weather. But if you do and ask to deviate 20 to the left, they're more than happy to accomidate you. And yes, sometimes I think the images may exagerate the returns. But once you get used to using it, you know what's what and what you can and can't fly through. Of course, sometimes if you are so equipped, you can go right over the top of some storms and that won't be reflected. That's where onboard radar would come in handy! Onboard is great for the local area, sat wx is great for the overall picture. Would be great to have both, but you can get sat wx for about 2000 bucks. Start with that. Go to anywheremap.com and look at that product. I think it WAY exceeds the Garmin 396. And yes, you can patch a DELPHI or any XM radio reciever and get perfect reception of over 100 channels. Truely awesome for those long trips. Sirrius does not offer weather, so you'll have to go with XM, which is probably better anyway. If you have XM weather, you can get XM radio under a family plan for only an additonal 6.99 per radio. Well worth it.
Get it! Awesome tool.
