siucavflight
Back from the forsaken
- Jul 30, 2003
Yea, it's called negligent homicide. But in order to get charged with it, two things have to occur. One, the actor must remain alive after the act. Two, somebody besides the actor, has to change their citizen status to cadaver.epic! said:wow that really sucks. doesnt the US have some law that prevent the crowd from getting hit at airshows?
FN FAL said:Yea, it's called negligent homicide. But in order to get charged with it, two things have to occur. One, the actor must remain alive after the act. Two, somebody besides the actor, has to change their citizen status to cadaver.
With that in mind, laws such as negligent homicide don't really "prevent the crowd from getting hit", but they do provide the criminal justice system with the appropriate legal tool to deal with those who do and survive.
Depends...WGP guy said:So what happens if the pilot lives, but someone in the crowd dies because of the crash, but the crash was caused by a mechanical problem. The problem happened on a part that hte A&P recently worked on. Would the A&P get the charge or the pilot? Both?
Eagleflip said:I think what Epic is describing is included in the FAA requirement concerning "directed energy" and crowd location. Obviously, this is a US issue.
Specifically, airshow pilots may not fly closer than 500, 1000 or 1500 feet (depending on the speed of the aircraft performing) to the crowd, with two exceptions --straight and level overflights and bananna passes, the latter allowing gradual descents and flight no closer than 500 to the crowd line.
That being said, no performer may perform any type of aerobatic maneuver in the direction of the crowd such that "energy" (in the form of aggressive maneuver, including rolls ) is in a vector toward the crowd. This includes rejoins or crossing passes, e.g. the Ramstein accident. The only exception to this last requirement seems to be the Thunderbirds maneuver with a fourship converging on a point, and I do not know what exclusion they are operating under, but I am sure it has been authorized by the FAA.
The only maneuvers that are allowed are straight and level overflights and high-g turns that take place away from the crowd, but briefly point toward them at the end of the 360.
FN FAL said:I test flew a 414 after an engine swap and an A&P accompanied me on the flight. We did the best pre-flight you could do and needless to say, we developed an un-known engine roughness problem on the new engine and landed.
The mechanic exited the plane while I secured the cockpit and all I could hear was cussing, the sound of the cowling hitting the tarmac, more cussing followed by the sound of footsteps and then the crash of someone's tool box being tipped over. Followed by more yelling.
When I got out of the plane, I saw a puddle under the engine, at least 6 foot square. The new engine and turbo housing was stained avgas blue in color, and smelled like avagas.
In the end, it was the fuel lines coming out of the Bendix unit that were finger tight only and had come lose in flight and were spraying that engine and turbo charger with fuel. There's no way I would have caught that one on the pre-flight and you'd be lying if you said you would have either.
Had we exploded on that flight, would the mechanic who signed off on the engine be criminally charged with negligent homicide? Could be...maybe...possibly? That law is on the books in our state...and most likely in your's as well. I just depends on whether or not your local prosecutor is going to push it in such a case.
A Squared said:Buddy of mine had a similar situation. In this case it was a oil line that wasn't tightened, and it didn't go quite as well. They were at about 10,000 ft on a test flight when one engine caught fire. They were able to put it down on a gravel bar and both walked away, so I guess it was a good landing.
Wow.agpilot34 said:The FAA regs discussed above pertaining to Aerobatic airshow displays only apply here in the US... this airshow was in Russia.
That's what the insurance companies are for...!!!WGP guy said:So what happens if the pilot lives, but someone in the crowd dies because of the crash, but the crash was caused by a mechanical problem. The problem happened on a part that hte A&P recently worked on. Would the A&P get the charge or the pilot? Both?
You can get insurance for criminal defense attorneys?rfresh said:That's what the insurance companies are for...!!!
FN FAL said:.
Wow.
agpilot34 said:As always, there's got to be at LEAST one smart a$$ed comment in every post. At least that is a constant around here.
That is pretty wild...most of those people look like they were killed right where they stood.MGlobemaster said:That's some pretty insane footage.....too bad it's real.
As opposed to getting hit by a jet moving 300 knots, then running away and dying a bit later somewhere else??FN FAL said:Most of those people look like they were killed right where they stood.
Huggyu2 said:As opposed to getting hit by a jet moving 300 knots, then running away and dying a bit later somewhere else??
See: FN FAL doesn't have the monopoly on smart-arse comments!
It does look weird to see the pilot standing there gathering up his parachute.VNugget said:Jesus....
on a side note, if you watch carefully, you can see them eject after the jet is already crashing
