minitour said:I'm gonna say no....but that's coming from a Cessna driver (172s)....
Why they going to winglets? Fuel efficiency?
-mini
Knob said:They may reduce the drag, look @ the difference between the 747-100 & the -400 though. Even with the winglets you better be a dot high on g/s when behind a -400!
scoreboard said:Well, I'd say the winglets increase aspect ratio and reduce drag as a result of vortices, so they reduce the vortices...
Vortices = Wake Turbulence. As mentioned, winglets are designed to dampen vortices to give the effect of an increased aspect ratio, which means less induced drag. Less vorticies = less wake turbulence because they are the same thing. Now is it enough to make a difference to your 172 if you fly through the wake of a 757? I seriously doubt it....minitour said:yes, but the question "will it ease up on the wake turbulence?" I still say no.
Again, coming from a Cessna guy....my 172 isn't gonna just go "oh...winglets....smoooooooth flyin" I'm still gonna have to be (as was said) a dot higher on approach.
-mini
Aw! No fair! How come we don't have winglets on our 135's??? Those would look totally sweet with my Oakleys and overly-gelled spiked hair!AirBud said:There was an article about this 3 or 4 months ago. The wake on the 757 is reduced by something like 30% with the winglets.
Check out
http://oea.larc.nasa.gov/PAIS/Concept2Reality/winglets.html
