aggiepilot
Member
- Sep 5, 2005
Ok guys,
Need a reality check.
1. Is it true that the night flying life expectancy is lower than the life expectancy for other pilots? Facts first then opinions please.
2. Is it true that the loss of medical rate is significantly higher at UPS versus the non-night time operators.
3. Also, is commuting from a SE city, (not ATL) a real possibility, even to ANC, or are you killing yourself. I commute now but only a 2 hour leg with 7 options a day but it is 4-5 work blocks a month where UPS seems to be 1-2 work blocks on reserve.
4. How hard is the lifestyle? Are the 4 leg nights common and miserable? Would you rather do one long leg international or domestic multi legs. With kids that wake up at 6:30 AM, do you make a life sleeping until 11 every day?
5. How much home time would you have as a commuter, do you lose one day one each end of the commute or can you get home on a day that you strat or finish, r(please specify if you are tlaking from a reserve or lineholder perspective)
Thanks for your detailed responses in advance!
