You're right, the Part 135 regs you qote seem to render the distinction moot, for Part 135 operations. It would seem though that it would still have implications for pilots under Part 91 only flying aircraft which are not certificated for flight into known icing, or known icing conditions, or however the AFM words ittranspac said:Why the concern about the definition of known icing?
rubberducky said:Actually I disagree with Weasil.
rubberducky said:If conditions that are conducive to icing are forecasted, that does not make them "known icing conditions"
rubberducky said:So if you see a forecast that would probably call for icing in the clouds you could still takeoff in a C172 for example
