JetDriver2727
Member
- Jun 30, 2005
lawfly said:A better analogy for V2 is best angle of climb speed with gear up, flaps takeoff, and takeoff thrust. It's all about the climb gradient. This is the 2nd segment of the climb, the 1st having ended with gear retraction/35 feet above runway, at V2. Indeed, the required minimum climb gradients for these segments is highest during the "V2 segment", i.e., during the second segment.
Venr is the target speed for the next segment, which involves flap retraction, reduction to max continuous thrust, and acceleration to Venr. This final segment generally begins at 400 agl.
I have not seen Vyse in the manuals for the Citation. While the rate of climb could be (is, I believe ) higher at Venr than at V2, the gradient is shallower because of the higher forward speed. I just looked at an FSI Citation handout, and Venr is defined therein as "Minimum Single Engine Enroute Climb Speed".
These are certification speeds in the event of an engine out scenario.
Vyse might be an okay analogy to Venr, although it would be just an analogy, as there is likely no published Vyse for the airplane, anyway.
You're right, I hastily left out the part about takeoff thrust, and even more carelessly I said V2 is best rate as opposed to best angle. Oops! even I make mistakes at 2:30 in the morning when I posted that.....But, I think everyine got the idea. You are correct that Venr provides for a higher climb rate, but shallower gradient then V2. I don't recall any Vyse speed being publised for any turbine powered part 25 airplane that I have flown so I agree with you there too. I have always been one to build analogies to keep things strait in my head, and I always remembered V2 as Vxse and Venr as Vyse. You are correct that it is only a loose analogy, but it helps visualize what you are trying to obtain with the aircraft.
