Can you "expect" them? I don't know. Can you get them? Sure. You can get vectors "direct" to most anything.geardown said:Can you except vectors to a VOR from a point outside of its service volume if you are under radar control.
The same thing that you would do under 91.185 for any other type of lost comm on vectors.If yes what do you do if you lose com?
geardown said:Thanks for the replies, How about if ATC gives you a vector for traffic or sequencing after you accept the scenario above. Are you still legal? I had this happen the other day, and never had any concern of getting to the navaid, however the legality of it was questioned.
#1, yes. #2, do the one in which you feel most safe at executing. "by direct route to the point being vectored", that was the final approach course, right?flyinghunter said:==============================
If being radar vectored, by the direct route from the point of radio failure to the fix, route, or airway specified in the vector clearance;
ok, how bout this... you are on radar vectors for an approach, we'll assume VOR with the VOR as both the IAP and FAF. Two situations, assuming the final approach course is on the 180 radial southbound, what do you do:
1. You are SE of the VOR on a "downwind" when you lose comms, I say direct VOR and then full approach.
2. You are NE of the VOR still on "downwind" when you lose comms, do you turn an immediate base to intercept and continue inbound or proceed direct the VOR and do the full approach. Does having a IFR GPS or any GPS adjust your opinion.
geardown said:Can you except vectors to a VOR from a point outside of its service volume if you are under radar control. If yes what do you do if you lose com?
