Using distance - Divide the HAT by 3 and plan to start the descent for landing that far from the runway.
HAT = 600' Start your descent 2nm from the end of the runway.
As a note, when using this method verify what the DME is at the threshold of the runway (typically the MAP). This can be seen on the profile view. For example, the MAP on a LOC approach is generally not 0.0 DME. It will more likely be somewhere between .5 and 2.0 DME. If the MAP is 1.2 DME and the HAT is 600', you would add 2nm to the MAP DME of 1.2 and plan to begin your letdown at 3.2 DME. If you did not correct for this difference and just started down at 2.0 DME, you would be well above the desired descent profile.
Figuring out your own "VDP" is an excellent tool for getting the airplane to a position where a normal descent to landing can be made. Just realize that figuring it on your own does NOT necessarily provide terrain clearance.
Hope this helps.
