As an express pilot, I obviously cannot list for the jumpseat. Is there a way within Sabre for me to check if one of you has listed for it on a particular flight?
I know G*flightnumber/datecity will give me the number of JSs for the equipment but not if someone is listed.
Actually, that SABRE command will tell you if someone is listed. If you look under the jumpseats, it will say two things....the number available and if you look just under it, it will say the number in use... If the number in use is blank, then no one is listed..That is my understanding anyway.
the besy way I have found is to type: (FOR FLIGHT #329)
LH329/18MAYPIT
This will give you all positive space bookings. If you see a last name with PRI or ALT, those would be mainline primary or alternate JS bookings indicating you aren't getting on. Hope this helps.
I didn't think that command would show "IF" someone was listed. I thought it would only show if the JS was in use after someone had already checked in for it.
erjman
I'll try that this morning.. Trying to get home and once again flights are full. Thanks!
