UPS Apps????
Accett16
Member
Anyone know the status of UPS accepting applications? Airline Pilot Central is saying UPS stopped accepting applications in May. Any info on this would be appreiciated.
Your info is correct; the application window has been closed for several months however the rumor is that it’ll be reopening very soon. The fact UPS will be attending the September AirInc job fair in Washington, DC could also indicate that.
As far as the transoceanic experience requirement - no one really knows. I've heard they'll start taking applications for pilots who do not meet the requirement but I've also heard it'll be a while before that happens. One pilot I flew with said they’ll have two online applications: for those with and those without the transoceanic experience. Again, until it happens it’s all just rumors. Good luck to you!
Looks like the window is kinda open -
https://ups.managehr.com/screening/...s=10&citystate=AL&jobcategorylst=2&keywordtxt=
Flight Officer
Requisition #22202883
Air Operations
LOUISVILLE, KY
JOB DESCRIPTION:
UPS operates one of the world's largest airlines using more than 600 aircraft to serve more than 200 countries and territories worldwide. The company's extensive air network includes international air hubs in Cologne, Taipei, Miami (to serve Latin America), an intra-Asia hub in the Philippines and, the UPS Worldport in Louisville, Kentucky (the four million square foot heart of UPS's global air network).
In addition to its airline, UPS is also a pioneer in developing aviation technologies to enhance the safety and efficiency of the aviation industry.
To keep us number one in the air, we rely on a hardworking flight crew who are responsible for the safe, on-time and efficient operation of our aircraft. That's why we provide our employees with a top-notch work environment, safe equipment, professional advancement opportunities and exceptional benefits.
If you are interested in being a part of the talented UPS workforce as a Flight Officer and “Synchronizing the World of Commerce”, please review the basic qualifications and answer the following questions, which is the first step to be considered for the position.
All applicants must possess the following basic qualifications:
  • Have a minimum of 1500 hours of total fixed-wing pilot time
  • Have a minimum of 1000 hours pilot in command (PIC) hours in fixed-wing jet and/or fixed-wing multi-engine turboprop
    • Pilot in Command, per FAR 1.1, means the person who:
      • Has final authority and responsibility for the operation and safety of the flight;
      • Has been designated as the pilot in command before or during the flight;
      • Holds the appropriate category, class, and type rating, if appropriate, for the conduct of the flight
Other requirements include:
  • Hold a valid passport
  • Bachelor's degree is preferred.
  • Recency and type of experience will be considered.
  • Have authorization to work in the United States
  • Be at least twenty-one years of age
Note: Please fully complete the application prior to clicking SUBMIT. Updates are not permitted!
BASIC QUALIFICATIONS:
  • Hold a current FAA First Class Medical Certificate
  • Hold a current ATP certificate OR hold an ATP written with a commercial pilot airplane multiengine land certificate with instrument certificate
  • Hold a current flight engineer written or current flight engineer certificate
  • Hold an FCC restricted radiotelephone operator permit
  • Minimum of 1500 hours of total fixed-wing pilot time. (UPS will allow military candidates to add a plus (.3) per sortie factor to flight times)
  • Minimum of 1000 hours pilot in command (PIC) hours in fixed--wing multi-engine turboprop per FAR 1.1. (UPS will allow military candidates to add a plus (.3) per sortie factor to flight times)
After you apply it says they will email you when the spot opens...but at least the is a sign :)
PUKE:puke:
Last night this link was not there - I'd say the window is either open again or it's about to open!
go to:
www.upsjobs.com
Select
- United States
Click on (left side)
- Professional Opportunities
Select
- Air Operations
Click on
- Flight Officer
Here's a direct link but often they go dead - if so, just follow the instructions above.
UPS FLIGHT OFFICER
Good Luck everyone!
Also, make sure you read this!
