UltraNav 800xp?
AOA
Active member
Hi Everyone,
Just wanted to run some real world comparisons. Does anyone have the 800xp UltraNav?
Really appreciate the help.
Thanks for the help;
Should have posted this earlier.. (also looking to see if there is a copy floating around)
800xp Looking for max weight possible off both dry and wet conditions
4500 ft long
1000ft elevation
OAT 15 deg C and OAT 25 deg C
Desire is to fly .8 hrs with RSV
6000 ft long
2000 ft elevation
OAT 20 deg C and 35 deg C
Desire is to fly 2.5 hrs with RSV
Thanks again,
4500 ft long
1000ft elevation
15 deg 25,800 Max, (ours is 16,500 bow) can do this easily (basically 7000 lbs with 8 pax)
burn 2100, 1800, 1700 (we push it up)
25 deg 24,600 max
6000 ft long
2000 ft elevation
20 deg: can do max to weight, (28k)
wet 21k to
35 deg: 25,400 tow (wet n/a)
should do 2.5 with 2000 reserve
Hope it helps kinda threw it together in a hurry.
Thanks again,[/quote]
