FoxJet
Who wants a MUSTACHE RIDE
- Mar 21, 2005
The reg you need to look at is 61.57. The likely answer is no because for typed rated aircraft your landings need to be in type to count for currency. There are alternate requirements for two pilot turbine aircraft but even they require landings in type within the last six months.
Not exactly. 61.55 requires that you perform and log engine-out procedures and maneuvering with an engine out while executing the duties of pilot in command; and Crew resource management training as well as the three take offs and landings.What I never realized before is that you only need three take-offs and landings in the previous 12 months to act as SIC.
PJ§ 61.55 Second-in-command qualifications...(b) Except as provided in paragraph (e) of this section, no person may serve as a second-in-command of an aircraft type certificated for more than one required pilot flight crewmember or in operations requiring a second-in-command unless that person has within the previous 12 calendar months:
(1) Become familiar with the following information for the specific type aircraft for which second-in-command privileges are requested—
(i) Operational procedures applicable to the powerplant, equipment, and systems.
(ii) Performance specifications and limitations.
(iii) Normal, abnormal, and emergency operating procedures.
(iv) Flight manual.
(v) Placards and markings.
(2) Except as provided in paragraph (g) of this section, performed and logged pilot time in the type of aircraft or in a flight simulator that represents the type of aircraft for which second-in-command privileges are requested, which includes—
(i) Three takeoffs and three landings to a full stop as the sole manipulator of the flight controls;
(ii) Engine-out procedures and maneuvering with an engine out while executing the duties of pilot in command; and
(iii) Crew resource management training.
(c) If a person complies with the requirements in paragraph (b) of this section in the calendar month before or the calendar month after the month in which compliance with this section is required, then that person is considered to have accomplished the training and practice in the month it is due.
