First descent rate required. Does anyone have a formula?
You're flying along at 300kts at FL240, in 12 miles you need to be at FL180, How many feet per minute descent? I can ballpark it but would like to be exact.
Also, passenger says you smell like you've been drinking whats your response?
1. Sounds like you got slammed dunk3ed. The controller must have been distrcted by his breakfast burrito....
Pretty easy one though.
300 kts is 5 miles/minuute
12 miles at 5 per minute would take 2.4 minutes.
6000' loss in altitude/2.4 minutes =2500
(check my math please)
Better answer is 3000fpm and get to the restriction 2 miles prior!!! (or program the fms and let vnav do it for you)
2. I had this happen to a buddy once. He immediately called the chief pilot, and told him personally he wanted to be taken off of the trip and tested to prove he was innocent. Pro-active stance got him out of alot of potential trouble. Can't be too careful these days.
I was thinking the 3/6 rule myself, but if you take 3x6 (altitude to be lost), you get 18 miles, but you only have 12 miles, so 1800 fpm would not be enough to get you down in time (6x3 for descent rate). So I guess you would have to use one of the other ways above for this question. probably done on purpose so the 3/6 rule doesn't work
