RafaelThielmann said:Aircraft components are $$$ and usually not for car use. If you want to improve your turbo readings, you could install a Pyrometer after the hot section (about 2-3" from the gas exhaust) and control the exhaust temperature for too poor or too rich fuel mixtures, and to control the turbo Rpm's you could compare inlet-outlet pressures..... Just an idea.
aircraft equipment are for aircraft applications.... don't get mixed up.
DeltaAir423 said:EGT and PSI gauges are all you should really need. The big thing to realize is your boost limits, before you start to either blow a seal or melt a piston. If your car is OBD II, you can purchase a really good scanner for around 1k and it will give you a true to life sensor readout so you can adjust things like fuel/air ratio mapping.
