The conclusion is…
TRAFFIC PATTERN ALTITUDE at AIRPORTS WITHOUT an OPERATING CONTROL TOWER:
Ref: 91.126 thru 91.131, 91.155, AIM 4-3-3d.1., AIM 4-3-4, AC 90-66A, Airplane Flying Handbook FAA H-8083-3
1. At most airports and military air bases, traffic pattern altitudes for propeller-driven aircraft generally extend from 600 feet to as high as 1,500 feet AGL. Also, traffic pattern altitudes for military turbojet aircraft sometimes extend up to 2,500 feet AGL. Therefore, pilots of en route aircraft should be constantly on the alert for other aircraft in traffic patterns and avoid these areas whenever possible. Traffic pattern altitudes should be maintained unless otherwise required by the applicable distance from cloud criteria (NOTE: there is different VFR distance from cloud criteria for Class G or Class E airspace).
2. 1,000 feet AGL is the recommended pattern altitude unless established otherwise… (AIM 4-3-4 [1])
3. There is a “RECOMMENDATION” (in AC 90-66A) that large and turbine powered airplanes should enter the traffic pattern at 1,500 AGL or 500 feet above the established pattern altitude. Apparently someone at the FAA feels it’s OK for a large aircraft to descend on top of a smaller aircraft (very possibly moving at a similar speed) during base to final.
4. Traffic pattern altitudes are occasionally listed in the Airport/Facility Directory, in which case the published altitudes would be somewhat regulatory. In some cases these airports actually have different altitudes for small and large or turbine-powered aircraft. In other cases there is only one altitude published, and that would be the altitude for ALL aircraft (unless you accept the recommendation of AC 90-66A and fly your large and invincible turbine 500 feet above everybody else — until you turn base to final — then descend on top of the other aircraft that was in the pattern below you the whole time flying at just about the same speed!).
5. Other “unofficially published” sources of traffic pattern altitude are the “Flight Guide” produced by Airguide Publications for VFR pilots; and the two different “Airport Directories” produced by Jeppesen and AOPA. These commercial publications list far more pattern altitudes than the A/FD, but very often disagree as to what these altitudes actually are!
6. The majority of Class G or E airports do not have “officially published” (in the A/FD) pattern altitudes. In which case you have your choice of the 1,000 AGL (for ALL aircraft) as recommended by the AIM — and/or 1,500 AGL for large and turbine powered as recommended by AC 90-66A — or personally calling the airport manager and asking if he has “established” a “recommended” altitude for “his” airport (an obviously imperfect system).
7. Large and turbojet aircraft are also governed by 91.515 which states those aircraft are required to maintain at least 1,000 feet AGL during the day and the altitudes prescribed in 91.177 at night. However this rule does not apply during takeoff or landing. When does “during takeoff or landing” begin? That is a good question that could be debated either way. There is another reference to minimum safe altitudes in 91.119 that states “Except when NECESSARY for takeoff or landing…”
8. Aircraft remaining in the traffic pattern should not commence a turn to the crosswind leg until beyond the departure end of the runway and within 300 feet below traffic pattern altitude, with the pilot ensuring that the turn to downwind leg will be made at the traffic pattern altitude. (AIM FIG 4-3-3)
9. “Recommended” traffic pattern speed limit is 200 kts.
That’s all I’ve got for ya.
The key document is AC 90-66A which is the (only) source of the “recommended” 1500 feet for large and turbine powered aircraft.
I hope this helps.
