uwochris
Flightinfo's sexiest user
- Dec 21, 2001
Hey guys,
I have some questions regarding turbine engines, and I hope someone can provide some feedback.
1. I do not quite understand the purpose of "stator vanes." I have read that they are mainly used along with axial-flow compressors, and that they simply help to keep the air flowing parallel to the longitudinal axis. Do they have any other purpose? ie) do they aid in compression at all? I have seen pictures where they are used in the compressor AND turbine sections of the engine.
2. I also do not quite understand what a "diffuser" is. I know they are used on a centrifugal-flow compressor. Is the air compressed in the diffuser, or does the diffuser simply direct the air flow to the combustion chamber?
In the Turbine Pilot's Manual, the author explains that "a diffuser is simply a divergent duct that slows the velocity of the impeller's output air, thereby increasing the air pressure before it enters the combustion chamber." This explanation, however, is not very clear to me ( I do not understand how it slows the air, and why the air pressure would need to be increased if it has already been compressed through the high-pressure compressor).
3. EPR is described as the ratio of engine output pressure to engine intake pressure (thrust output/thrust input, or turbine discharge total pressure/compressor inlet total pressure). I am just wondering where are the pressures measured (i.e. where are the probes located). It seems to me that if the engine output pressure is measured where it is discharged, the pressure would be very low (i.e. the exhaust gases pass through the turbine blades, and are accelerated through the nozzle. If the pressure were to be measured here, it would be very low, and thus, the EPR gauge would read low.). I am just thinking that if the air pressure were to be measured at a point where it is accelerating, it would read low, compared to where the air is entering the compressor section.
4. My understanding of a "hot start" is that it occurs when the compressors are not turning fast enough, causing the mixture to pool up and build in the combustion chamber, leading to very high temperatures and pressures. Is this correct? I read that they occur when the expanding gases do not travel aft through the engine.
Thanks in advance for any replies,
Chris.
Chris.
