Transport Category
time builder
I've searched the AIM for definitions on aircraft categories and couldn't find a definition for transport category. Is there a weight involved, or is it like utility/normal/acrobatic where you base it from the load factors which can be placed on the plane and its aircraft specific.
Transport category planes are certified under Part 25 and Normal/Utility/Acrobatic/Commuter are certified under Part 23.
Depends on the context in which it is used. For example, a B-727 is normally considered a transport category aircraft, however, not for the purpose of describing it as being certified under part 25, because it is was not certified under part 25.
The B-727 is a transport category airplane because it was certified under the transport category rule in effect at that time, CAR 4b. FAR Part 25 came along later and superceded CAR 4b.
bocefus said:
Ummm, yeah, The point was, B-727 was not certified under part 25.
Yes, and i think that the other point was that the 727 was certificated under the equivelant predecessor part.
Stating that the 727 was not certificated under Part 25, without mentioning CAR4b, while not incorrect, is at least as misleding as saying transport category aircraft are certificated under part 25
Umm yeah, what is misleading, is to state that FAR 25 and CAR 4B are equivalents, because they are not. Ask yourself why 727's were produced and certificated under CAR 4B even when FAR 25 was effective and in place. Why do civil airworthiness authorities continue to release supplemental inspection/maintenance requirements that are only required to comply with the regulation that was in effect at the time of original certification? After all, if they are "equivalents" why wouldn't they simply require compliance with the current certification regulation?
Transport catagory aircraft are either,
Jets with 10 or more seats or a Maximum Takeoff Weight (MTOW) greater than 12,500lb; or
Propeller-driven airplanes with greater than 19 seats or a MTOW greater than 19,000lb.
The TCDS will state transport category on the top of the first page if it is. Some small jets like the Sabre were transport category aircraft.
Really? Where do we find this definition? You mean that a FAR 29 certificated
transport category helicopter is not an AIRCRAFT? As I said, the definition of "Transport Category" Depends of the context in which it is used.
