satpak77
Marriott Platinum Member
- Dec 2, 2003
well, I can't quote climb rates, but I will say this, once you truly "go vertical" the only thing that matters is thrust to weight ratio. Lift, by definition, is perpendicular to relative wind, which means that in a vertical climb, lift has no vertical component. It doesn't mater at that point what your lifting surfaces are doing, it's all thrust and weight.Airpiraterob said:.....so do your high speed pass....go vert. and nothing will catch you.
I'll take SAM for 500.Airpiraterob said:so do your high speed pass....go vert. and nothing will catch you.
A Squared said:well, I can't quote climb rates, but I will say this, once you truly "go vertical" the only thing that matters is thrust to weight ratio. Lift, by definition, is perpendicular to relative wind, which means that in a vertical climb, lift has no vertical component. It doesn't mater at that point what your lifting surfaces are doing, it's all thrust and weight.
"THE NEED FOR SPEED"sydeseet said:I just gotta......
"I FEEL THE NEED!"
(Back me up here boys)
EagleRJ said:When you "go vertical", do you need to establish a pitch angle of 85 degrees or so, to ensure your flight path is 90 degrees (assuming angle of incidence is not zero)?
Jedi_Cheese said:I think there would be a (small) market for used F-14's... if the US goverment will sell them (which is doubtful).
coolyokeluke said:Many of the flying scenes for the movie were piloted my the executive officer of the aircraft carrier I was on, Captain Winnefield. Last I heard he was commanding officer of the Enterprise and on the very fast track to put stars on his shoulders.
Sorry to bring this up so late, but I was doing a little lunchtime searching.atrdriver said:And doesn't the F-15 "streak eagle" hold all the current time to climb records?
atrdriver
