I've been fighting this issue since bringing home the new FX-3, at times the aft fuel drain drips and won't seal. I've tried running quite a bit of fuel through it, snapping it from open to closed, twisting it, staring at it, nothing works. I reached out to CubCrafters and apparently these things are prone to this so I ordered two more, one for replacement and one for a spare which apparently is recommended to have. I also learned about these from my fellow cub owner @turbopilot and everyone involved suspected either FOD or a failed o-ring.
Sadly there is no fuel shutoff for this line so I'll have to fly down the fuel to the lowest I'm comfortable with and drain the rest and then replace this contraption. I ordered two from CubCrafters at $30ea or you can order from Aircraft Spruce I realized after I ordered for about half that. Yaye me. I'm not quite sure what thread sealant to use but Pete gave me a sample of something called "EZ turn fuel lube" so I guess that's it. I also noticed on my CubCrafters' invoice the o-ring that this part takes and quite frankly that's all I probably need but if removing the drain why not replace it to be sure? But I ordered a few o-rings from Aircraft Spruce as I have hoarding issues and now I can add more spare parts to my toolbox
I'll keep you posted but here are links to parts should you ever need them.
MS29513-006 O-RING
FUEL DRAIN SAF-AIR CAV-160
EZ Turn Lubricant
MS29513-006 O-RING
MS29513 Fuel Resistant O-Rings | Aircraft Spruce
MS29513 Fuel Resistant O-Rings These MS29513 series O-rings are resistant to fuel and are ideal for applications such as fuel injection connections and primers. A small amount of fuel proof grease applied to these O-rings helps the...
www.aircraftspruce.com
Saf-Air CAV-160 Pushtype Fuel Drain Valve | Aircraft Spruce
Saf-Air CAV-160 Pushtype Fuel Drain Valve SAF-AIR push type fuel drain valves are close tolerance valves of simple design. These valves provide the most trouble free operation of any other line valves in the industry. SAF-AIR valves are man
EZ Turn Lubricant
EZ Turn Lubricant | Aircraft Spruce
EZ Turn Lubricant EZ Turn is a specialty lubricant/sealant used for fuel and oil line valves & is resistant to high temps. Especially effective where high octane fuels and aromatics are present. EZ Turn is also e...
