This aircraft is flown on a Part 135 certificate based based on the west coast along with 2 other DA-2000's. The aircraft has a full time crew along with full time "floater" pilots to provide days off.
Other than that, this is all I know. Hope this helps.
The aircraft N659FM used to be under Flightworks managment. The owner pulled the aircraft and put it on Elite Aviation's certificate. They are based out of Van Nuys, but have other bases. One of the Captains is great friends with the owner, they used to be Navy Seals together.
