Brett Hull
Pastafarian
- Nov 25, 2001
Are you required by regulation to follow an RA if you are operating under part 91? The only things I can find is 91.221, which basically says if you have it installed, you must turn it on. Also, 91.123, which says if you respond to an RA, notify ATC ASAP.
The boss and the other guy at work says you have to follow one if you get it. I say you don't. Who's buying beers?
Please don't turn this into a "why would you not want to" argument.
