User997 said:When I was doing my flight training in the Pipers, I was taught as part of the Taxi Checklist to switch tanks. When I asked the instructor about it the first time we did it, he said it's a good idea to switch tanks on the ground to make sure that there won't be problems switching over once inflight. He had a good point , and I still do it to this day when flying Pipers or other aircraft that you have to feed from one tank or the other.
When doing a cross country flight, I usually plan most of my waypoints around/over airports, so that if anything goes awry, I always have a place close by to put down. With that in mind, I typically only switch fuel tanks while over or close to a nearby airport. Therefore if anything does go wrong, I have a suitable landing place to glide to. And if I don't have an airport nearby, I always have a emergency landing spot picked out prior to the switch-over.
I'm just safety concious like that.
Rally said:I personally think switching tanks is a bad idea on the ground
